Author Topic: 69 vs 70 Instrument Cluster  (Read 1278 times)
Offline mjgraniero
« on: August 01, 2014, 09:13:45 AM »
I have a 70 cluster for my 69 unfortunately.  A friend has a 69 cluster that he's willing to swap for my 70. Both wood grain. The 70 almost looks like a light cherry finish. Can anyone tell me if the values between the two are the same and should be an even swap?
Mike
1969 Mustang Fastback (in restoration)
428CJ, Ram Air
C-6
9F02R
Offline 69GTconvert
Re: 69 vs 70 Instrument Cluster
« Reply #1 on: August 01, 2014, 01:16:58 PM »
If the two clusters are the same condition and both have the same gauges, I would think it's an even swap. It starts becoming uneven if one cluster is in better shape than the other or one is a tach cluster and the other does not, etc.
George
Georgia
1969 Mustang GT Convertible
390 4V, Close Ratio 4 Speed
Royal Maroon - Black Standard Interior w/ High Back Seats
« Reply #2 on: August 01, 2014, 01:31:12 PM »
Hey Mike I don't remember the particulars on your car so...  My car is an early production car September 68 Metuchen with 3A interior.  For 69 there were two styles appliques used Teak and Walnut and with seemingly no definitive plant or date.  The grain and color of the applique is applied in several other areas and you should probably try to match.  Don't forget the dash harness needs to have a correct plug in at the cluster. If you can get the correct style tach/no tach or warning lights vs gauges and with the correct matching applique a straight across swap would be the ideal situation.  My opinion of course.  Brian
« Reply #3 on: August 01, 2014, 01:55:24 PM »
IMHO if they are both deluxe wood grain ones, they have the same gauges (tach or no tach) and the condition (check the back side for burn outs and problems) then they are equal since your getting what you need and getting rid of something you don't.   I would want to see if they had the matching passenger side and your going to need to consider what your using for the inserts for the door panels. you might have a bunch of different panels as far as tone and tint
Just what I'm thinking - not being able to look at shat your working with
