Author Topic: Tranny Tunnel Holes - Oct 64 SJ  (Read 1079 times)
Offline livetoride60
« on: July 31, 2014, 07:33:39 PM »
Anyone know what these holes are for?  Maybe 3/4" in diameter.  One on each side of the tunnel at the toe board seam with the floor.  Not sure if they are original.  The smaller screw holes between them were for a console I assume.
Oct 64 SJ Hipo Fastback.
Offline wunderwerks
Re: Tranny Tunnel Holes - Oct 64 SJ
« Reply #1 on: July 31, 2014, 09:39:17 PM »
Possibly a previous installation of an incorrect Ford underdash AC.  One of the 65 units from another model from Ford had a drain holes on each end of the lower case.   Just a guess on my part.
64.5 Cpe. Poppy Red 5F07D 23G
64.5 Conv. Bright Cherry Sparkle 5F08F 16F
65 2 + 2 Caspian Blue 5F09K  23K
« Reply #2 on: July 31, 2014, 10:24:51 PM »
The one on the left looks like the speedo cable hole for a 4sp.  The one on the right looks like one made by previous owner for A/C.
« Reply #3 on: July 31, 2014, 11:15:44 PM »
The 4 speed cable hole is farther up, as shown in this pic.  It did have a dealer type installed AC unit in it.  Inside evaporator unit was real Ford 66 model with one drain, but the brackets were aftermarket, so assume the right hand hole at least was for AC drain.
Just making sure they weren't supposed to be there before they get welded up.  Any other ideas let me know.
« Reply #4 on: July 31, 2014, 11:43:11 PM »
Ahh, got the orientation wrong for the speedo cable, you are right that it's the one further up.  So, looks like those holes were made later for a/c.
« Reply #5 on: July 31, 2014, 11:54:22 PM »
Ok, thanks Charles.
