Author Topic: Brake and hub question  (Read 1092 times)
Offline qman
« on: July 29, 2014, 11:32:08 AM »
We are restoring a 1969 Metuchen built scj car assembled in May. The car is a non power drum brake car. My question is: Did Ford use a variety of front hubs based on engine size or brake options or are the hubs all the same?
Re: Brake and hub question
« Reply #1 on: July 29, 2014, 02:41:34 PM »
The 69 Shop Manual.  Brian
Offline qman
« Reply #2 on: July 30, 2014, 08:43:23 AM »
I appreciate you taking the time to answer my questions, unfortunately the attachments aren't very clear.  Would you please post those attachments again and I'll try to find the shop manual you used.
« Reply #3 on: July 30, 2014, 02:27:22 PM »
Might try a right click on your mouse and select from the drop down menu ' save picture as... ' and it will go to your pictures file.  From there it is possible to magnify as well as save.   If none of that works send me your email address and I will sent you copies.   Good Luck.  Brian
« Last Edit: July 30, 2014, 02:43:24 PM by Brian Conway »
