Author Topic: My Dec 65 NJ Mustang - Feedback please  (Read 4823 times)
Offline 66RavenGTCoupe
« on: July 22, 2014, 11:35:18 PM »
Here is my Dec 65 Bucked 66. Decal was placed in the exact same place as it was originally prior to the restoration. I made a template of the original position and located it with the front suspension dust cover bolts that go down the side of the shocker tower.
« Last Edit: July 24, 2014, 05:18:31 AM by J_Speegle »
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: Re: MAR 66 METUCHEN service decal
« Reply #1 on: July 23, 2014, 06:12:02 AM »
Looks good Raven,
I'm pretty sure your windshield washer bag should have gold lettering instead of white?
Bryan
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #2 on: July 23, 2014, 08:11:39 PM »
Thanks Bryan,
I appreciate the comment and the info on the washer bag. Don't know if you saw it but I actually started a thread on exactly that question as I was unsure so thanks for clearing that up. Was there a changeover date for these or did different plants use different ones?
I would be happy for anyone else to comment on things that they feel are incorrect as well. So don't be shy!
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #3 on: July 23, 2014, 08:56:54 PM »
.......I would be happy for anyone else to comment on things that they feel are incorrect as well. So don't be shy!
This might get carried away (off thread) so we can split this if needed.
Just noticed a few typical things that stand out
1- Shocks
2- unpainted master cylinder
3- looks like the bypass hose and clamps might be unpainted
4- Electrical wire clip on the drivers side radiator support ??? One on the passenger side looks out of position from what I'm use to seeing
5- lack of sealant on the firewall - most noticeable at the heater motor and mounting studs but would expect the electrical connection sealant will be minimal or missing also
6- Red wire covering or something else - mid firewall just uncer the cowl to firewall pinch weld??  In the passenger side picture
Looks like a great job and allot of attention to details :)
« Reply #4 on: July 23, 2014, 09:23:47 PM »
Thanks Jeff. This feedback is great as I really want to represent this car properly for history's sake.
Just in reply. I'm waiting to restore the original Koni shocks so I have that one covered.   ;)
Upon close inspection of the master cylinder prior to restoration I found no evidence of paint ( plenty of surface rust though!) I researched it and found that they were either raw or black. Is that incorrect? :-\
Need to paint bypass hose and clamps - thanks.   :-[
There was absolutely no evidence of sealant on and around the heater fan and mounts. Could this have been missed on the line? Where would the electrical connection sealant be? I have sealant right across the top of the cowl.
The red thing that you see mid cowl is the neutral safety switch connector  :D that is correct right?
Battery mount is incorrect. Temporary fix while I save for an Autolite Sta Ful. (Christmas can't come fast enough!!)
Thanks again for your feedback so far.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #5 on: July 23, 2014, 10:24:05 PM »
So I'm guessing your playing the dealer installed option thing with the shocks ;)
Must be looking at the MCA rules ;) the only IMHO reason the natural finish is still in the rules is because that was the expected finish from the 70-90's and the powers that be didn't want to upset cars that have been finished and shown for years. Its not unusual for the master cylinders to rust and out be splashed with brake fluid - both will eliminate the paint
At least one box/crate of original assembly line master cylinders was located many years ago - all painted as a unit just like the years that followed.  Also plenty of original cars and pictures have been found to support those findings
Could it have been missed on the line - possibly but would have likely been caught by one or more inspectors if it had. Ford had a on going problem with sealing out the water and elements from the interior which was stressed by dealers annually at meetings. These complaints continued for years so I would expect that its something the line inspectors and plant managers too seriously   or should have at least
The product used as an adhesive not like the sound deadeners (thick heavy stuff used in later years) and does not always hold up well or stand out as much as some of the other products  - seam sealer in the trunks and interior for example
As expected I do have a few pictures of the product and patterns applied to NJ cars
Not a problem - just stood out in the picture - not sure if I've ever seen it up that high on a car
« Reply #6 on: July 24, 2014, 02:57:00 AM »
Yep. That's my angle! Hehehe!
Great info! Will repaint when I tackle the front 4 pots.
 Is love to see those pictures Jeff  8)
Please read above section - I have not worked out how to "quote" and "unquote" yet
Do you have a pic of that too?
Appreciate the invaluable feedback Jeff. This is like gold to me.  :D
This was the original bay....,
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
Re: My Dec 65 NJ Mustang - Feedback please
« Reply #7 on: July 24, 2014, 05:19:25 AM »
Split the topic - will post some 66 NJ firewall pictures tomorrow - its late ;)
Offline ChrisV289
« Reply #8 on: July 24, 2014, 10:56:08 AM »
Aren't some of the valve cover bolts supposed to be painted as well.  I know it was discussed in another thread...
2009 V6 Mustang Coupe
Offline Hipo giddyup
« Reply #9 on: July 24, 2014, 01:32:42 PM »
 How about the front of the PS pump?? It looks to have been painted with the case. I know the case is painted that "specific" PS color but was the front painted with it as an assembly, left cast, or maybe painted black then assembled??? Asking because I am unsure myself. ;D
« Reply #10 on: July 24, 2014, 01:35:55 PM »
Pumps were painted either semi-gloss black or the blue teal color depending on the supplying company (tag will provide that info)
The cast pump, the reservoir/can, tag and retaining nut were all painted as a unit. 66RavenGTCoupe's looks fine unless I'm missing a detail
« Reply #11 on: July 24, 2014, 04:31:13 PM »
Thanks for the clarification. Can you elaborate what on the tag would result to be an all black pump or all teal? Which manufacturer? Thanks
« Reply #12 on: July 24, 2014, 04:58:51 PM »
ford pumps are teal. just remember 'ford blue'.
« Reply #13 on: July 24, 2014, 08:28:03 PM »
Take a look at the FAQ's at the top of the 65-66 section - question #7  ;)
There are there since the question gets asked ALL the time - or we knew 5 years ago that you would be asking that exact question today   ::)
« Reply #14 on: July 24, 2014, 09:11:51 PM »
Not sure how many pictures you need - let me post some of the ones that are clearer shots of the product and application. If we need more I can always post others
Working passenger to drivers side. On some took and highlighted the sealant pattern sicne it might not be all that visible in the original picture
#1 PS Firewall
2# PS Firewall
#3 Center Firewall
#4 DS Firewall
#5 DS Firewall/Master Cylinder
#6 DS Electrical Connections
The purpose/goal was to seal every attachment point (except for the engine ground) and pass through on the firewall
