Author Topic: Shifter Control Rebuild Kit  (Read 3255 times)
Offline Alpha1946
« on: July 23, 2014, 12:39:58 PM »
Does anyone know where I can purchase 4 speed toploader Shifter Control Rebuild Kit and Trunion bolt set?
Toploader Heaven no longer sells any shifter parts.
appreciate any help
64.5 Wimbledon White Convertible
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
Re: Shifter Control Rebuild Kit
« Reply #1 on: July 23, 2014, 02:29:47 PM »
The bolts that attach the shift handle to the shift control can be bought at any Mustang parts place, sure you can find them on ebay too.
Otherwise, what other parts are you looking for?
Offline Alpha1946
« Reply #2 on: July 23, 2014, 02:59:04 PM »
Charles
I am removing a Hurst shifter that previous owner added and replacing it with an original Ford toploader shifter I obtained from a wrecking yard.  I thought I would disassemble, clean and install a shifter rebuild kit from Toploader Heaven but they he no longer carry any shifter parts. Felt it might be wise to have the rebuild kit available when I start to reassemble because I don't know what I will need until I take apart.
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
« Reply #3 on: July 23, 2014, 03:32:03 PM »
Finding a ford top loader shifter in a junk yard is quite a score.  Congratulations,  Brian
Offline Alpha1946
« Reply #4 on: July 23, 2014, 03:40:45 PM »
Thanks Brian.
Probably should have used a different description rather than wrecking yard.  It was actually an old rusted Mustang behind an old store near Buffalo Texas sitting along side old tractors and pickps.  All of the parts were gone or rusted beyond use but I told the person what I was needing and he had shifter and links inside and that was about all he had.
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
Offline 5F08KGT
« Reply #5 on: August 31, 2014, 01:25:00 PM »
Is Bill Heeley in Olney, Maryland still in business?? if so HE IS THE FORD SHIFTER EXPERT EXPERT HANDS DOWN!!
Offline Alpha1946
« Reply #6 on: August 31, 2014, 01:44:49 PM »
I purchased these items from Bill.  He was very helpful and prompt on shipping.
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
« Reply #7 on: August 31, 2014, 03:40:22 PM »
............. I thought I would disassemble, clean and install a shifter rebuild kit from Toploader Heaven but they he no longer carry any shifter parts. Felt it might be wise to have the rebuild kit available when I start to reassemble because I don't know what I will need until I take apart.
Good idea - Typically what I've done, Check for heavy wear to the moving parts and joints on disassembly. If a show car then plating time ;)
Lube it going back together, making sure everything travels nice and smooth. Throw new trunions, springs and insulators (if the model uses all of those) and you should be happy.
Offline Alpha1946
« Reply #8 on: August 31, 2014, 07:52:40 PM »
This is what Bill recommended also.  I purchased the rebuild kit, new trunions, springs, insulators, levers, set of linkage and all of the installation hardware so I should be ready to go.
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
