Author Topic: Need picture of firewall with air conditioning  (Read 3838 times)
Offline kammertime
« on: July 21, 2014, 10:05:17 AM »
I need a picture of the firewall under hood area  where the heater core and a/c unit are mounted.
Re: Need picture of firewall with air conditioning
« Reply #1 on: July 21, 2014, 12:09:21 PM »
what year?? what plant?? what engine?? help us out please!
Offline kammertime
« Reply #2 on: July 21, 2014, 08:56:58 PM »
1969
Dearborn
428 CJ
« Reply #3 on: July 21, 2014, 09:53:30 PM »
Not sure if you need the openings or some other detail
Here are a few examples - if you have something specific your looking for let us know
Sorry didn't know the production period either so just threw some out there. Not easy to find nice clear pictures of the area once the engine and everything is in place :( shock tower supports, engine and hose .... always in the way
Hate to show a restored car but here one is - lacking the hoses, expansion valve and the insulating wrap
Offline kammertime
« Reply #4 on: July 22, 2014, 10:05:02 AM »
Jeff,
Thanks for the pictures. It appears that the original heater hose openings are plugged. Are those plugs avaiable ?
« Reply #5 on: July 22, 2014, 08:33:19 PM »
Jeff,
Believe the plugs are - always seem to find them in my boxes or collection of new plugs.  Often buy those cheap big collection of plugs and just use what I need and what fits especially considering their going to get a heavy coating of sealer
Offline 1970shelbyguy
« Reply #6 on: January 13, 2015, 07:35:36 PM »
hey jeff-  did vacc'm can  ( by hood hinge) get any blast from the spray on sealer. -  also was brake line installed prior to air cond- hence overspray on line.   blower motor  shield didn't get any correct?  for  a dearborn  69 june 428 cj  . thanks
1970 gt500  grabber blue  june/69     1970  boss 302  metuchen  dec/69
« Reply #7 on: January 14, 2015, 05:05:47 PM »
The can was in place when the sound deadener was applied in the front wheel well - on Mustangs  but not Shelbys since they didn't apply the same coatings there
Heater, brake lines, AC plate and motor shield were installed after the firewall was painted engine compartment black but before the firewall sealer around mounting nuts, connections and pass throughs
« Reply #8 on: January 14, 2015, 08:51:22 PM »
thanks jeff-  going to spray on some shutz to a/c cover area tonite
Offline Buiaka
« Reply #9 on: January 24, 2015, 01:22:42 PM »
Where do i get this retainer for the vacuum hoses on the firewall showed in the second picture?
Mine is missing.
Greets
« Reply #10 on: January 24, 2015, 05:23:50 PM »
Mine is missing.
A donor car or make one yourself.  You can use tool dip to reproduce, repair or replace the rubber coating. The rest is basically some strap steel cut to the correct length and shape much like the wrapping straps used on the AC lines
