Author Topic: 67 GT500 Thermactor questions  (Read 20840 times)
Offline 2112
Re: 67 GT500 Thermactor questions
« Reply #45 on: August 07, 2014, 11:46:11 AM »
That vacuum tube route in that picture would not be applicable to your particular Shelby application .  The delete sheet was for a series of Shelby cars built all the same way (with the exception of color)not your particular car like a conventional build sheets. I have yet to find or hear of a conventional build sheet found in a 67 Shelby although it was no out of the ordinary to find a add+delete sheet in one. They were typically found in the car under the carpet.
I doubt very much previous owners would have left the add/delete sheet while they had the interior apart.
Which picture would be incorrect? The two I posted?
« Reply #46 on: August 08, 2014, 01:30:43 AM »
Just posting where they are found and not commenting on the possibility of finding in your restored car. The rear mount valve in Jeffs reply #40 that you commented "wow" on.
« Last Edit: August 08, 2014, 01:32:51 AM by Bob Gaines »
Offline 2112
« Reply #47 on: August 08, 2014, 01:46:17 AM »
Thanks for clearing that up for me.
Offline 2112
« Reply #49 on: November 01, 2014, 03:48:23 PM »
I thought Bob posted a picture comparing 67' and 68' thermactor tubes but I can't seem to find it now.
I am looking at pictures of 67' cars and I can't see the difference in their tubes and these;
http://www.ebay.com/itm/Smog-Emissions-Thermacter-Tubes-1968-1970-428-Cobra-Jet-Mustang-Cougar-Torino/171071532650?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D27538%26meid%3D5519b7ed2d4d452e849392a0cf311842%26pid%3D100005%26prg%3D11353%26rk%3D3%26rkt%3D6%26sd%3D181374684390&rt=nc
I am sure Bob or Jeff will straighten me out.
« Reply #50 on: November 01, 2014, 06:59:03 PM »
The quickest IMHO way to take note of the differences is illustrated in the following two pictures. Top a 67 design the lower a 68-70 design. Hope this helps
Offline 2112
« Reply #51 on: November 01, 2014, 07:10:28 PM »
That does help. Thank you
Is that the only difference?
« Last Edit: November 01, 2014, 08:29:31 PM by 2112 »
Offline dieseldave
« Reply #52 on: December 05, 2014, 09:28:49 PM »
On the 1967 left side GT500 thermactor tube is there a support bracket? The pictures 2112 posted I can't see the bracket...
« Reply #53 on: December 05, 2014, 11:39:16 PM »
Its cut/modified from the 390 application
« Reply #54 on: December 05, 2014, 11:42:40 PM »
As in cut off .
« Reply #55 on: December 05, 2014, 11:48:13 PM »
As in cut off .
(trying to sound like a hill person we both know) ...... aint cutting a modification ?  ::)
« Reply #56 on: December 06, 2014, 12:56:24 PM »
hay hay there  I heard that   :)
