Author Topic: '68 license lamp metal finish  (Read 3116 times)
Offline Oz390
« on: July 19, 2014, 08:34:27 AM »
The license lamp housing is a base of two pieces riveted together, then the screwed on lens retainer (cap).  Are all 3 pieces zinc dichromate ("gold zinc") finish?
(Excluding the bulb socket which appears to be a press fit to the base after the finish is applied)
8R03S : 76A I 2A 15M 72 5 U
Re: '68 license lamp metal finish
« Reply #1 on: July 19, 2014, 12:22:14 PM »
Yes gold. As you surmised you press out the socket for replating.
Offline Anghelrestorations
    • Anghel Restorations
« Reply #2 on: July 19, 2014, 04:53:28 PM »
Yep, not very different from the 69 and 70 versions you see here.  You can see a better picture on my website
Marcus Anghel
www.anghelrestorations.com
« Reply #3 on: July 19, 2014, 06:45:41 PM »
+1  and yes you simply reinsert the build socket after plating. Did a dozen or more of these the last time we did dichromate. IMHO always try and plate three or more examples of everything. Then you can pick out the best (if the part is an undated one), sell the left overs or save them for the next project
Offline Oz390
« Reply #4 on: July 19, 2014, 07:03:28 PM »
Thanks for confirmation.  Any tips on pressing out the socket? Only have the one and do not want to damage it...
« Reply #5 on: July 19, 2014, 07:14:36 PM »
I find a long/deep socket that fits inside the socket in place of the bulb, a 6-8" extension on the socket and while supporting the bracket with a thick towel I strike the end of the extension a couple of times with a piece of wood (normally just a 10-12" section of 2"x4")   Sure a rubber mallet would work in its place.
« Last Edit: July 19, 2014, 07:16:50 PM by J_Speegle »
Offline Oz390
« Reply #6 on: July 19, 2014, 08:15:37 PM »
Thanks very much...
Will give it go, like my small dead blow hammer for this type of stuff....
« Reply #7 on: July 19, 2014, 09:02:52 PM »
Yes, the sockets come out pretty easy actually as long as they are not too corroded.
Marcus Anghel
Offline Oz390
« Reply #8 on: July 19, 2014, 09:47:57 PM »
Yep, pooped out pretty easy, with the right advice!
Do folks remove the rubber boot for replating the socket, plate it with the rubber on, or not do it?  Again, afraid to destroy the one boot I have as if I don't plate it its not the end of the world. (to me!)
« Reply #9 on: July 19, 2014, 09:54:51 PM »
you can plate with the rubber on but once plated you need to thoroughly oil and coat the inside of the receptacle and spring area otherwise the spring will corrode and maybe break.
Offline Oz390
« Reply #10 on: July 20, 2014, 01:00:38 AM »
Ok, thanks again.
« Reply #11 on: July 21, 2014, 12:16:03 AM »
IIRC, the socket is made of brass.
