Author Topic: 68 GT 350 Aircleaner Mounting  (Read 3216 times)
« on: July 18, 2014, 09:44:50 PM »
Does any one have a picture of a 68 GT350 air cleaner with the lid off showing the hardware mounting the base to the carb?
Built 12-02-67 if it matters.
Offline TLea
Re: 68 GT 350 Aircleaner Mounting
« Reply #1 on: July 22, 2014, 07:44:18 AM »
Marty I am assuming you are using the air cleaner I sold you? If so there is no hardware under the lid. Base sits there, filter goes on and sadwiched when you put top on and attach wing nut. A pre recal base/lid is different but I dont think thats what you are looking for
« Reply #2 on: July 23, 2014, 12:08:45 AM »
The Build date was 12-02-67 # 602 and it was not brought in for the recall.
 We have fabricated this structure so we would not have to drill another hole in the top
What I am asking is what hardware fastens the base to the carb?
Offline TLea
« Reply #3 on: July 25, 2014, 12:01:46 AM »
Short length of threaded rod with nut that has captured spinning washer similar to battery hold down nuts.
Pre recall? so cast iron manifold and Marchals?
Offline TLea
« Reply #4 on: July 25, 2014, 12:02:56 AM »
Marty what is your Ford VIN?
« Reply #5 on: July 25, 2014, 12:22:56 AM »
On that bracket with the large hole I was thinking of using a flat washer and a fiber lock nut. I will do the concours correct hardware when I restore the whole car. I am very concerned about hardware coming loose and being ingested in to the engine.
The car's VIN is 8T02J126886 built 12-02-67 It has the original Marchals and cast intake with the Autolite 4300. Interestingly it also has a 6A interior. I think most had the comfort weave knitted vinyl inserts.
Thanks for your help I plan to have it at the Lincoln MCA national show are you going to be able to make it?
Marty
Offline TLea
« Reply #6 on: July 25, 2014, 08:17:31 AM »
You would think that was an issue but I've never heard of it happening. The reason I ask about VIN is my vert is 126778 built 12/1. Your car has tllt I assume?
I will not be at Lincoln, maybe Savannah
« Reply #7 on: July 25, 2014, 08:28:55 AM »
Yes it has tilt and AC. I wish you could have seen the car and given me a few tips. Thanks again!
« Reply #8 on: July 26, 2014, 12:14:40 PM »
Marty
If you are concerned about the nut working loose and falling in the carb you can also substitute a bolt in place of the threaded rod and nut(still use washer) . I have seen more then a few of that type of solution over the years and early 68.
« Reply #9 on: July 26, 2014, 07:07:26 PM »
If you are concerned about the nut working loose and falling in the carb you can also substitute a bolt in place of the threaded rod and nut(still use washer) . ..........
And a little thread lock on the threads or a little aviation form a gasket
« Reply #10 on: July 26, 2014, 11:32:53 PM »
Thanks for all of the help.
Marty
