Author Topic: 1966 MUSTANG CARBURETOR RECOMMENDATION  (Read 5023 times)
Offline 69cobrajetrugae2
« on: July 18, 2014, 03:58:52 PM »
I need the correct carburetor for my mustang.  It is a 66 C code convertible with a T-10 4 speed and was born in San Jose in 6-4-66 and delivered to the Seattle district.
Here are the recommendations on the Mustangtec website.  Are there any other carburetors not listed here that are concourse correct?
The car does not have the smog equipment, the engine has not been touched except for the carburetor.
The engine tag information is as follows.
289 C 66 10
6 D 231 8
MUSTANGTEC CARBURETOR  RECOMMENDATIONS
C6DF-A
6D-A
1.14 venturi
Manual Trans
 C5ZZ-9510-L
C6DF-B
1.14 venturi
Manual Trans
 C5ZZ-9510-L
C6DF-E
1.14 venturi
Manual Trans
C6DZ-9510-C
Thank You Very Much.
« Last Edit: July 18, 2014, 04:27:13 PM by 69cobrajetrugae2 »
Re: 1966 MUSTANG CARBURETOR RECOMMENDATION
« Reply #1 on: July 18, 2014, 04:20:53 PM »
I need the correct carburetor for my mustang.  It is a 66 C code convertible with a T-10 4 speed and was born in San Jose in 6-4-69 and delivered to the Seattle district.
289 C 66 10
6 D 231 8
C6DF-A
6D-A
1.14 venturi
Manual Trans
 C5ZZ-9510-L
C6DF-B
1.14 venturi
Manual Trans
 C5ZZ-9510-L
C6DF-E
1.14 venturi
Manual Trans
C6DZ-9510-C
Did you mean 6-4-66 inside of 69 ?
« Reply #2 on: July 18, 2014, 04:27:38 PM »
Yes sorry, 66.
« Reply #3 on: July 18, 2014, 05:55:21 PM »
     I have a C6DF-B carb.  You have it listed for a manual trans.  I believe the B code was for an automatic.   Brian
« Last Edit: July 18, 2014, 06:55:32 PM by Brian Conway »
Offline aaatp
« Reply #4 on: July 18, 2014, 07:18:16 PM »
The shop manual for 1966 shows the following.
C6DF-A   289-2V standard transmission
C6DF-E   289-2V standard transmission with thermactor emissions
C6DF-B    289-2V automatic transmission
If you have the themactor emissions, then C6DF-E is what you need, if no thermactor emissions, then C6DF-A would be the choice.
« Reply #5 on: July 18, 2014, 07:24:20 PM »
Wow, thanks guys!  It seems mustang tech is wrong on this one. I will search for the A.  Are there any other details that I should look for when purchasing a used Carb?
« Reply #6 on: July 18, 2014, 07:26:33 PM »
worn/stuck throttle shafts, warpage, missing parts come to mind.
Offline DKutz
« Reply #7 on: July 27, 2014, 12:50:58 PM »
Ok so I have a four barrel but you guys have me worried.  I didn't know there was a difference from automatic and manual carbs.  I thought a 4100 was a 4100.  What are the differences?
« Reply #8 on: July 27, 2014, 01:06:27 PM »
My understanding is that the biggest difference is AT's have a dashpot on the throttle shaft, therefore a different suffix.
Richard
« Reply #9 on: July 27, 2014, 01:24:53 PM »
if you obtain a factory shop manual it will have the different specs listed.
« Reply #10 on: July 27, 2014, 02:27:42 PM »
The basic housings are the same for 66 Mustangs except for the 289HP, it's some internal components and adjustments that make the differences; here are some:
- Jets; smog, non-smog; operating altitude; transmission type.
- Dashpot: AT only.
- Booster Venturi: both primary and secondary.
- Economizer: operating altitude.
- Choke: TN for AT, TO for MT.
- Adjustments: idle speed.
In general, you can take any 1.08 inch venturi size 66 Mustang carburetor and adapt it to any 66 Mustang specification by changing components and making the proper adjustments.
« Reply #11 on: July 27, 2014, 06:36:23 PM »
     The type of carb is id'ed by the last letter, in this case, C.  The C is a manual trans carb.  The 1.08 0r 1.12 is cast into the fuel float bowl.  There are also service replacement carbs.  Post whatever numbers you can find and these guys will help you figure it out.  Brian
« Last Edit: July 27, 2014, 06:51:50 PM by Brian Conway »
« Reply #12 on: July 27, 2014, 07:17:31 PM »
They are:
C6ZF-9510-A MT
C6ZF-9510-B AT
C6ZF-9510-C 289 HP MT
C6ZF-9510-D MT Cal Smog
C6ZF-9510-E AT Cal Smog
C6ZF-9510-F 289 HP AT (also most Hertz Shelby AT)
