Author Topic: Do you think this is the correct amount of overspray? Dearborn Sept 64  (Read 2759 times)
Offline markb0729
  • South Jersey
I'm painting an early Dearborn built (September, 2 1964) 65 Fastback Vintage Burgundy.  We are working in the trunk and I was wondering if you folks think that the amount of over spray on the inside rear quarter panels is sufficient?  Below are a couple of pics (Sorry, the driver side pic did not come out too good.  The over spray coverage is a little more than the passenger side.)  Thoughts?
Driver Side:
Passenger Side:
« Last Edit: July 18, 2014, 12:59:16 AM by J_Speegle »
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
Re: Do you think this is the correct amount of overspray?
« Reply #1 on: July 17, 2014, 08:28:31 PM »
With the glare its hard to tell but since you used the term "overspray" I would guess the answer is no - since the interior surface of the quarter panels in the trunk did not receive overspray normally but instead direct paint application just like the exterior of the car The surfaces above - towards the front (over the wheel wells) and the top corner of the quarter panel to quarter extension panel would have had little or no paint - overspray
Surface over the sound deadener would typically get a nice coat of paint
Offline markb0729
  • South Jersey
« Reply #2 on: July 18, 2014, 12:37:13 AM »
Ok.  When all said and done, I didn't think it looked right.  So at this point do you think it would be better to paint the inside of the rear quarter panels?
« Reply #3 on: July 18, 2014, 12:58:31 AM »
Yes IMHO
Couple of examples
Offline markb0729
  • South Jersey
Got it!  The pics put everything into perspective.  Thanks so much.
What we're here for :)
Offline GT500KR
  • Charlie Ping
Re: Do you think this is the correct amount of overspray? Dearborn Sept 64
« Reply #6 on: August 14, 2014, 02:14:07 AM »
Jeff,
 Those are some great pictures. Is that an original example, or a correct restoration? is it typical to have the black strip caulk-like caulk pushed into the unused quarter panel hole after paint?
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 Jalapeño Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
« Reply #7 on: August 14, 2014, 02:22:55 AM »
Jeff,
Normally I don't save pictures of many restored cars. If I do its for the purpose of showing what not to do ;)   thought not always - so if you see me taking pictures please don't assume
It's a very nice unrestored car that came out for a show a few years back after not being showed for maybe 20 years before that where I saw it before we had digital camera
Yes had to seal those holes
Offline GT500KR
  • Charlie Ping
« Reply #8 on: August 14, 2014, 10:10:42 AM »
Thanks! that helps a lot.
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
07 Black GT500 Cp
