Author Topic: 1966 Fan Shroud Mounting / Hot Idle Compensating Valve  (Read 4351 times)
Offline msmith
« on: March 20, 2010, 11:29:35 AM »
I recently purchased an NOS fan shroud and a 7-blade clutch fan for my 1966 to bring it up to correct A/C equipped spec. I also found an NOS Hot Idle Compensator valve.
I'm hoping someone has detail photos of the Ford fan shroud and mounting hardware (installed), and of the hot idle compensator valve (installs on the PCV line) so I can do it right the first time.
Thanks in advance!
(1966 Dearborn-built Convertible C-Code 289 2V, built November, 1965)
« Last Edit: March 20, 2010, 11:35:35 AM by msmith »
Offline msmith
Re: 1966 Fan Shroud Mounting / Hot Idle Compensating Valve
« Reply #1 on: March 28, 2010, 03:50:03 PM »
Anyone???  :-[
« Reply #2 on: March 28, 2010, 04:17:17 PM »
Have some pictures I'll post when I get home. Many of use have been judging or attending a show this weekend
Offline msmith
« Reply #3 on: March 28, 2010, 07:35:40 PM »
Thank you, Jeff... much appreciated.
« Reply #4 on: March 30, 2010, 12:03:18 AM »
Looked and I found no good reference pictures - hopefully someone else will be able to post
Neither is real difficult to describe - just no good pictures
Offline msmith
« Reply #5 on: March 31, 2010, 12:53:56 PM »
Thanks for looking, Jeff... if anyone has a decent photo of original fan shroud mounting brackets and screws, I would really appreciate it!
Offline msmith
« Reply #6 on: November 10, 2010, 03:24:13 PM »
One more bump after six months to see if anyone can help me out with fan shroud bracket pics.
Thanks.
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
66 Metuch Conv
Nightmist, Std Blu Int
Offline msmith
« Reply #8 on: November 12, 2010, 04:37:07 PM »
Thank you, Briancobb!!! You rock.
Offline MustangCountry
« Reply #9 on: November 18, 2010, 01:45:14 AM »
If you still need pics or any help with the Hot idle compensation mounting, let me know. I have a 1965 convertible with one currently mounted on the pcv hose. I can send pics and measurements if needed.
Rick
Rickyracer99@gmail.com
Offline msmith
« Reply #10 on: November 18, 2010, 04:42:59 PM »
Thank you, Mustangcountry... e-mail sent.
Offline 66RavenGTCoupeAgain
« Reply #11 on: June 08, 2016, 10:46:05 PM »
This may help this thread.....
I am chasing part numbers for all the other bits shown here? Can anyone help?
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
Offline Chris
« Reply #12 on: October 31, 2018, 11:28:28 PM »
The hot idle compensator valve details are listed in Bob Mannel’s book. You have that reference?
« Reply #13 on: August 02, 2019, 02:27:44 AM »
I do Chris but there is no mention of the threaded adapter and barbed elbow or part numbers relation to them. I'm wondering if its a backyard or dealer installation or if it is indeed a factory practice.
Offline 67350#1242
« Reply #14 on: August 02, 2019, 03:32:08 PM »
On my 67 the stock formed pcv hose was simply cut and the compensator spliced in.  Uses the regular pcv valve, no threads or brass block.
There is some discussion snd pictures here:
http://www.concoursmustang.com/forum/index.php?topic=15989.msg101446#msg101446
« Last Edit: August 02, 2019, 03:35:25 PM by 67350#1242 »
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
