Author Topic: Need PPG code for Wimbledon white  (Read 3114 times)
Offline fast66
« on: July 14, 2014, 05:45:45 AM »
Hi,
I had a little accident with my 66 Fastback and need a modern PPG version of the Whimbledon White color.
Trying to find the old code, 8378,  in today's system did not succeed.
thanks for any help!
Claes
6T09K212784
63A 4 25 21B 951384 5 6
Offline sanluis09
Re: Need PPG code for Wimbledon white
« Reply #1 on: September 11, 2014, 05:55:11 PM »
Hi,
I'd restored a 65 wimbledon white. The best thing I found was to match the paint from a part of your car (e.g a headlight bezel, etc). Or just wait until the new Mustang arrive at the dealerships and workshops, so you could ask for the WW code of the Limited Edition.
Regards
sanluis09
1965 WW Hardtop, 289-2V, 3-speed manual transmission. Unrestored. Assembled in Mexico on the time frame of: Oct 64-Feb 65.
« Reply #2 on: September 12, 2014, 10:58:00 PM »
Don't know if anyone has done a reformulation of most of the original colors in the modern paints and toners. IF they have they are not sharing the mix but instead selling the paint.
Since Wimbleton white is a very popular car you might get lucky with an individual owner - if they attached the mix to the outside of the can they had made up
Good luck with your search Claes
Offline 1969 Cale II
« Reply #3 on: September 13, 2014, 10:48:37 AM »
I called the shop I buy my paint(PPG) from and that 8378 is a good number and you can get it mixed any way you want, DBC to Delstar. Need help, email me.
Offline fast66
« Reply #4 on: September 17, 2014, 01:39:26 AM »
Thanks all for your suggestions!
The part of the car that was hit has been painted - it is perfectly painted but not perfectly matched...
it is not a panic situation as the car should be Arcadian Blue  - and will be so in due time, but it could have been closer.
Getting a recipy for this paint is not as easy over here (Sweden) as it may be on your side of the big pond.
br
//Claes
6T09K212784
