Author Topic: 69 351 Automatic driveshaft markings  (Read 3060 times)
priceless
  • Guest
« on: July 12, 2014, 07:55:01 AM »
Tried the search, and come up empty. Was wanting to know if anyone would know the driveshaft markings/stripes for my Metuchen NJ built, Feb.24,1969,  69 Mach1, 351W 2 bbl, single exhaust, FMX transmission, no P/S, no A/C.
Thanks for any help.
« Last Edit: July 12, 2014, 04:22:00 PM by J_Speegle »
Re: 69 M Code Automatic driveshaft markings
« Reply #1 on: July 12, 2014, 04:19:40 PM »
Easy one since its the same as we used on the 69 GT350 I did
CHLAWT - Chartreuse, Lavender and White
Original marks (one can see why pictures are not always good ways to document specific colors)
Comment - top example the chartreuse is more green and the lavender is more purple. White is just dirty
Bottom sample the chartreuse would be more yellow (chartreuse is sort of in the middle of both of these - you can look up samples of the color many places on the web)
How I reproduced what we found on this driveline. Orange was applied to the one york before it as welded in place.  On my monitor the colors are better/closer than the pictures above. Lavender could be a bit darker - less pink I guess
priceless
  • Guest
Re: 69 351 Automatic driveshaft markings
« Reply #2 on: July 15, 2014, 09:56:27 PM »
Thanks Jeff.
Offline drummingrocks
« Reply #3 on: July 17, 2014, 10:29:37 AM »
What's the red mark that's down past the white mark?
« Reply #4 on: July 17, 2014, 01:15:00 PM »
What's it for ??  Have no idea - though its not unusual to find addition markings on drivelines we don't understand all of their purposes and meanings at this time. The red band happened to be on the driveline when  it was cleaned so we returned it to the same spot like we attempted to so with the drips and runs from the ID marks
Offline Aussiemach
  • Silver Level Subscriber
« Reply #5 on: July 18, 2014, 07:43:07 AM »
Can I add to this thread by asking the same question of drive shaft markings for a 1969 Mach 1 351w FMX Built in San Jose, February 26 1969 ?
Here is what I have found on mine, stripes appear to be white, lavendar & black, is that correct ?
« Reply #6 on: July 18, 2014, 02:23:32 PM »
Would not match what is on build sheets from that time period that I'm looking at nor other cars I've got pictures of equipped the way your car is
Offline Aussiemach
« Reply #7 on: October 12, 2014, 02:42:40 AM »
Thanks Jeff, after your comment I measured the dimensions of my driveshaft, does not match what should be there
