Author Topic: Shaker Trim Rim Stud Repair  (Read 874 times)
Offline rvandier
« on: July 03, 2014, 11:49:47 PM »
Does anyone have any tips on how to repair/replace broken studs on the shaker trim ring? Mine has one stud broken off about half the length.  I thought about using JB Weld but still have to figure out a replacement stud to use--thanks for the help!
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
Re: Shaker Trim Rim Stud Repair
« Reply #1 on: July 04, 2014, 02:34:21 PM »
I have not gone out and looked, but an old 69 coupe side ornament has 6 studs. Maybe one off one of those would work?    I would probably finish off breaking it and JB welding a whole stud.  Also make sure the nut will screw on with out much pressure so as to not break it off after all your work.  Just a thought.
MCA#31064
Offline rvandier
« Reply #2 on: July 04, 2014, 04:42:35 PM »
Good thought--If I can find a replacement stud that's close in diameter and length I'll try the JB Weld method and see what happens.
