Author Topic: 67 headlight buckets,sprayed,dipped? semi-flat or satin  (Read 1540 times)
Offline gimpystoy
« on: July 03, 2014, 05:53:21 PM »
^7 headlight buckets (Metuchen) were these sprayed or dipped?
Is correct finish semi-flat or satin black.
Same as engine compartment?
TY,
Gimpy
67 C code Metuchen, May "67" build 289 C4
Re: 67 headlight buckets,sprayed,dipped? semi-flat or satin
« Reply #1 on: July 03, 2014, 08:47:52 PM »
Trying to remember if I've ever seen drips, runs or curtains and honestly I can't. Would say that the finish is much closer to gloss than engine compartment black IMHO.
Sure you'll get some additional observations
Leaving the post here because even though you focused on 67 and plant (thanks) the finish and applications I believe applies across many years, and plants
Offline gimpystoy
« Reply #2 on: July 04, 2014, 06:19:39 PM »
Jeff: big TY, as always
I placed it here not knowing if there were any plant variations.
 I've had the pleasant discover that me buckets were only mildly rested. a little steel wool + Eastwood rest encapusulator & I'm ready for paint.
Gimpy
