Author Topic: SJ Vert or not Vert?  (Read 1259 times)
Offline 66RavenGTCoupe
« on: June 30, 2014, 12:43:14 AM »
Looking to buy a 65 vert made at SJ. Only problem is that it does not have the holes at the front of the inner fenders near the front hood bumper stops for the additional braces that verts normally have. Door data plate is a Marti reproduction so I can not check against it. Vin on inner fender says that its a vert though. Has holes for a Monte Carlo bar. I've heard of some 64 1/2 generator cars not having them but this is a Oct 20 1965 scheduled car. What's going on?
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Re: SJ Vert or not Vert?
« Reply #1 on: June 30, 2014, 12:25:11 PM »
Those braces were a running change in 1965 (aka pre 64) and standard on 66 convertibles. There may be a TSB that Jeff posted here that gives more info.
« Reply #2 on: June 30, 2014, 03:07:18 PM »
The braces were added into regular production around Nov '64.
There is a TSB that describes how to add the bracing to earlier convertibles without them.
« Reply #3 on: July 04, 2014, 08:10:00 PM »
So is it a definite that this car was not originally a convertible even though the vin on the inner apron says that it is? Both aprons are without any holes for the original style braces. don't want it if it has been chopped and changed. Really confused here. :-\
« Last Edit: July 04, 2014, 08:14:14 PM by 66RavenGTCoupe »
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
Offline Ivygreen65
« Reply #4 on: July 04, 2014, 08:32:18 PM »
I think your confusion comes from the fact that you think the build date of the car was October 20, 1965, when the build date was actually October 20, 1964.  Since the braces didn't go into production until November 1964, as Charles noted, I wouldn't expect this particular car to have them unless they had been retro-fitted.
« Reply #5 on: July 04, 2014, 08:43:59 PM »
Hey Ivygreen,
That explains it! Thanks for clearing that up.  ;D
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
