Author Topic: '68 trunk anti rattle rods  (Read 2556 times)
Offline Oz390
« on: June 26, 2014, 03:42:40 AM »
Have seen two variations, not sure if either is correct.
One is a small "C" clip on both rods, near the middle, not attached to anything.  The other is an "M" shaped retainer screwed to the underside of the deck between the trunk lid and rear window clamping both rods to the metal in the middle.
Have also seen some with a spiral "hose" on one rod. Some none...
What is correct for a '68, and does it vary between early and late, or by body style (I have a convertible and 3 coupes).  San Jose (early convertible, early and late coupe) and one Dearborn (late).
8R03S : 76A I 2A 15M 72 5 U
Re: '68 trunk anti rattle rods
« Reply #1 on: June 26, 2014, 08:26:43 AM »
The most common seen is the spiral wrap. I have seen the C clip on San Jose cars. I have not see the M clip on any coupes or convertibles. I have seen a clip on a 67 fastback. Others here may know more about what plants used what and when. If possible post a picture of the M clip.
Marty
Offline tim_morrison82
    • Click Here for My Project
« Reply #2 on: June 26, 2014, 10:19:45 AM »
my 14M SJ  coupe has the spiral on the top rod. is your 14M SJ car similar richard?
Offline Murf
« Reply #3 on: June 26, 2014, 03:00:12 PM »
Our April 04 scheduled built date coupe (San Jose plant, California Special) has the "C" configuration.
John Murphy
Offline Dudley
« Reply #4 on: June 26, 2014, 03:53:16 PM »
My SJ June '68 build.
Offline Oz390
« Reply #5 on: June 26, 2014, 05:36:19 PM »
My April GTCS has some type of clip, do not have a good pic.  Possibly the "S" type shown.   But no spiral wrap.
Anyone with a '68 convertible that can confirm if its the same as the S clip shown in the '68 coupe above, with or without the wrapped rubber?  Mine has just the spiral rubber, which is different to the GTCS, but it is an early build San Jose (Dec '67) maybe a body style difference or a pre-post-strike change???
I think the "M" clip may have been off a 66.
« Last Edit: June 26, 2014, 05:37:53 PM by Oz390 »
Offline TLea
« Reply #6 on: June 26, 2014, 06:08:40 PM »
Metal clip vs spiral is early/late thing and varied by plant. I would put  change as February ish
April car would have clip
Offline Oz390
« Reply #7 on: June 26, 2014, 07:34:06 PM »
Thanks Tim, so the "pre-Feb-ish" 68's would have both the rubber spiral wrap, and the "M" clip?  Later only the S clip (which I believe matches my April GTCS, need to check on it next time I am in the shop)?
« Reply #8 on: June 26, 2014, 09:17:55 PM »
Did a survey of my pictures of 68 San Jose cars and found the following
Painted wrap with no clip  to No wrap - with clip change appears around the 13641x - 13850x period
8R01C13641x being the lowest VIN (coupe) I've got with the no wrap and with clip and 8R01C13850x being the highest VIN with the painted wrap with no clip
This should put the change in the early Feb period as Tim suggested
