Author Topic: 69 Brake caliper finish  (Read 2480 times)
Offline 69eliminator
« on: June 20, 2014, 06:55:28 AM »
What is the correct process for finishing the front brake calipers?
They appear to have a anodized coating of some sort on mine
As always, thanks for the help.
« Last Edit: June 21, 2014, 12:53:13 AM by J_Speegle »
1969 Cougar Eliminator 428 CJ Q Code with AC , PS, PDB, C6 Transmission,Traction-Lok Diff. 3.00. Bright yellow paint.
Dearborn 6/69
Re: Brake caliper finish
« Reply #1 on: June 21, 2014, 12:52:57 AM »
Front calipers are basically just cast iron bare steel. If your asking about the stamped steel shields (not the dust shields) I've found many that were galvanized on 69- 70's
Re: 69 Brake caliper finish
« Reply #2 on: June 22, 2014, 01:52:03 AM »
Hmmm
« Reply #3 on: June 22, 2014, 02:20:24 AM »
Hmmm
Got some details to add/offer? ... or did you fall asleep at the keyboard :)
Its all about sharing, the correct info  and we all have things to learn
« Reply #4 on: June 22, 2014, 11:54:58 AM »
from what I seen the silver coated calipers are only on certain cars depending on which wheel option to hide the rusting of bare steel on caliper when seen thru the mag spokes or slotted openings & I have 2 that came that way from the Dearborn plant & some that are bare steel. On 69 shelbys ford painted front face black but how was this coded on build sheet or buck tag or ?
« Reply #5 on: June 22, 2014, 05:47:44 PM »
So since the poster appears to be building a 69 Cougar Eliminator would they IYHO be bare or plated with some silver stuff?   ;)
Offline Anghelrestorations
    • Anghel Restorations
« Reply #6 on: August 21, 2014, 12:04:56 PM »
I am working on exactly this part of the suspension this weekend and can post photos of what I believe is correct so we can look and comment.  I am working on brakes for a 69 Mach 1 so could be a good comparison.
Marcus Anghel
www.anghelrestorations.com
Offline Dirk Pitt
« Reply #7 on: August 22, 2014, 08:41:18 PM »
While not doing a Cougar, I was advised that the caliper is a natural finish and the dust shield is a cold galvanized finished.  I've attached some photos to show how mine looks.
1969 Mustang SCJ (W-code), Dearborn Built 4/21/1969
1969 Mustang CJ, Dearborn Built 7/16/69
« Reply #8 on: August 25, 2014, 10:22:04 AM »
Update
Dearborn 6/69
