Author Topic: Which Intake Vacuum Valves Would I Need?  (Read 2524 times)
Offline 69GTconvert
« on: June 18, 2014, 06:01:02 PM »
I am looking to add the original intake back on my 69 Mustang but I'm not sure if I need a Distributor Vacuum Control Valve and am confused about which intake vacuum port I would need. Some info about my Mustang that may help:
- Built April 8, 1969 in Dearborn
- 390 4 speed car
- DSO in New Jersey
- Power steering
- Disc brakes.
1. Would I need a Distributor Vacuum Control Valve installed in the thermostat housing?
2. Based on the options I listed above, which intake vacuum port would I need from the pictures below?
Thanks.
« Last Edit: June 18, 2014, 06:07:02 PM by 69GTconvert »
George
Georgia
1969 Mustang GT Convertible
390 4V, Close Ratio 4 Speed
Royal Maroon - Black Standard Interior w/ High Back Seats
Re: Which Intake Vacuum Valves Would I Need?
« Reply #1 on: June 18, 2014, 09:32:00 PM »
Look on the Mansfieldmustang site, he has color pictures of intakes with those parts in the PCV section.
Offline Mike_B_SVT
« Reply #2 on: June 18, 2014, 10:13:51 PM »
Here is a link to the page mentioned above: http://mansfieldmustang.com/EnginePCV.html
And the '69 390 intake setup, after 2-21-69 pic: http://mansfieldmustang.com/04-42.jpg
Quote
"Need"?  Not necessary for the car to operate normally.  Its purpose was to change the timing (by porting vacuum) if the car reaches a hot / overheat condition.
If you have one to install, then go for it.  If not, then you can put a plug in the thermostat housing port and install the control valve when you have the desire.
If you are talking about installing one for "correctness"... um, I don't have an answer for that one >.>
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
« Reply #3 on: June 18, 2014, 11:15:30 PM »
Since this is the Concours site  - of course you would/will since it would not be restored without it
Also referred to as a PVS Ported Vacuum Switch
The vacuum tree that you posted would attache to the other larger vacuum block at the rear of the intake
Closest match I have is a Non AC, PB, PS  manual trans NJ 69 From the 9T01S151xxx  period
And a Dearborn examples (ignore the PO manual choke upgrade :)
Both cars still have the Autolite 4300' s so not allot of things have been done to these cars. Not restored by a long shot
In both it appears that there is a single hose attachment at the rear unlike the one you posted which has two hose connections
« Reply #4 on: June 19, 2014, 11:53:48 AM »
That brass block was added after engine was painted & should never be painted & different types depended on options p/b tilt shaker a/c etc. but the 1 you have in picture is most common.
Offline 69GTconvert
« Reply #5 on: June 19, 2014, 03:50:44 PM »
Thanks everyone for your feedback, pictures and links.
I contacted Mansfield Mustang about which intake vacuum port would be correct for my application. The picture posted on their site shows a brass block with a threaded hole on one side (maybe for the disc brakes) and two other vacuum ports like the picture of the brass block I posted. Mansfield told me a Mustang could have come with a brass block from the factory with additional ports and if some were not needed, they would be blocked off with a rubber plug. He told me they grabbed whatever was available at the time on the assembly line.
Most of the brass blocks I have seen for my Mustang come with the two vacuum ports and a larger threaded hole on one side. I have not seen a brass block with only one opening as were posted in Jeff's pictures, but I'm still looking.
George
Georgia
