Author Topic: Upper Control Arm detailing  (Read 2633 times)
Offline bjf1992
« on: June 10, 2014, 10:44:50 PM »
Were the upper Control arms and spring perches bare steel or were they Phosphated originally?
« Last Edit: June 13, 2014, 08:17:38 AM by carlite65 »
1969 Q Code Standard Cougar Convertible P/S, P/B, A/C
Pastel Grey, Lt. Blue interior Black Top
Built April 2nd, Dearborn
1969 Mustang Sportsroof
September 68 Build date, Metuchen
Re: Upper Conrtrol Arm detailing
« Reply #1 on: June 10, 2014, 11:11:32 PM »
what year ??? what plant???
Offline bjf1992
« Reply #2 on: June 10, 2014, 11:33:05 PM »
Oops sorry!   Dearborn Plant April 1st 1969
« Reply #3 on: June 11, 2014, 12:16:21 AM »
Bare steel.
Offline Anghelrestorations
    • Anghel Restorations
« Reply #4 on: June 11, 2014, 02:53:16 AM »
Would always be bare steel regardless of plant from what I have seen.  The phosphate process is just something some people are using on restored control arms and spring perches, was not done originally.
Marcus Anghel
www.anghelrestorations.com
« Reply #5 on: June 11, 2014, 12:09:39 PM »
Just to elaborate on Marcus's post the reason why some use the zinc phosphate is because it helps in it's slight non corrosion properties as well as providing a microscopic foothold for oil or other rust preventive coatings to cling to. It also builds up the surface ever so slightly helping to disguise pitting.
« Reply #6 on: June 12, 2014, 07:06:28 PM »
I may as well post some pictures here to show the difference that me and Bob are talking about.  This first picture here shows a phosphate finish on a set of control arms correct for 1969.
And these 1970 lower control arms are done with a bare metal finish without phosphating that would more similar to the original finish.
Marcus Anghel
« Reply #7 on: June 12, 2014, 11:09:27 PM »
One thing that you loos with phosphate IMHO is the weld bluing of the a arm on top of the lower where the pieces were put together  and the difference in the look (again on the lower) of the two different metals - the ball joint retaining plate and the sheet metal arm. Just me :)
Re: Upper Control Arm detailing
« Reply #8 on: June 13, 2014, 07:01:32 PM »
Good point Jeff.  You can see that contrast here in the bare metal arms that I am doing...
Marcus Anghel
