Author Topic: Early Mustang End Caps  (Read 1597 times)
Offline lscman
« on: June 09, 2014, 05:51:32 PM »
I'm thinking the early 64.5-65 tail light body end caps had a washer with sealer under installed before they were put on the car.Can anyone confirm this?
Re: Early Mustang End Caps
« Reply #1 on: June 09, 2014, 06:50:13 PM »
    Rear quarter exts ?  C5ZB-6528072-B.  Brian
« Reply #2 on: June 09, 2014, 07:53:04 PM »
Those look like later ones (quarter extensions) - they have the provision for the sealing strip
As far as the original post - not sure. Luckily the detail can't be seen  and there is sealant installed from the inside of the trunk before the nut and large wavy washer . The washer you speak of may have been part of the spacers that held the extension away from the body during painting. They may have been  meant to be removed - no way of telling at this point
« Last Edit: June 09, 2014, 08:05:58 PM by J_Speegle »
« Reply #3 on: June 09, 2014, 07:59:12 PM »
Early would be C4ZB-6528072-A (and 073-A, as C4ZB-6527702 - 3), without a grove for the seal, and yes they did have a flat washer (44720-S8), a sealer washer (358768-S) and a nut with a large sems type washer (353958-S100). Both washers are carried by AMK, the nut is not. Ford also used a lot of calk to keep exhaust fumes out of the car. Some federal regulation thing.
Offline lscman
« Reply #4 on: June 10, 2014, 09:32:08 AM »
jwc,those appear to be Ford part numbers?Do you know what the part numbers at AMK are?
Offline lscman
« Reply #5 on: June 10, 2014, 09:33:48 PM »
After doing some measuring etc. off original washer I found on another car nothing special about the washer.I miked it and run of the mill washer but Thanks for the help!
« Reply #6 on: June 11, 2014, 12:38:27 AM »
The steel washer, 44720-S8, is AMK B-12993 (20 ea, $3), the sealer washer, 358769-S, is AMK B-13742 (12 ea, $3). AMK also sell the calk sealer in gray, 0.19 in dia, a 13 ft roll, B-11608 $20.
For information, Ford hardware part numbers that are 5 numbers long are usually SAE standard sizes and you may find a commercial equivalent in a local hardware store (you need the dimensions to do this), the 6 numbered one are specials.
