Author Topic: Engine Final Assembly Plant Code "Z"???  (Read 2047 times)
« on: June 07, 2014, 10:54:35 PM »
My 67 Mustang has one of the Late 289's built on a 302 block and today I was able to read the final assembly date.
7G6Z
I thought the late 289's that had the 302 block casting numbers were made in Cleveland.
Is "Z" a valid code? It is clear as day!
Richard
« Last Edit: June 07, 2014, 11:08:08 PM by 67gtasanjose »
Re: Engine Final Assembly Plant Code "Z"???
« Reply #1 on: June 07, 2014, 11:47:58 PM »
Z is a common short hand code for 'Mustang'. The Z may have been placed on the block to differentiate it from other engine assemblies. That is my guess anyways.
« Reply #2 on: June 08, 2014, 12:00:25 AM »
Scott, it's rather funny you would respond first...This engine came from a 67 A-code w/Thermactor...COUGAR!
Richard
« Reply #3 on: June 08, 2014, 12:12:26 AM »
If the date code you are referring to was on a "boss" near the distributor, it decodes to year (7 - 67), month (G - July), day (6 - 6) and the "Z" is -- either the inspector or assembler's code (inspector seems to be more appropriate).
« Reply #4 on: June 08, 2014, 12:18:20 AM »
Yes, on the boss near distributor at the head gasket plane.
I understood that  much about the date, but I thought the last letter was supposed to be a "C" Cleveland or a "W" Windsor.
I'm no expert, just trying to learn to better understand decoding dates etc.
Richard
« Last Edit: June 08, 2014, 12:21:43 AM by 67gtasanjose »
« Reply #5 on: June 08, 2014, 06:10:41 PM »
Nope - last letter (According to a TSB article about that stamping) was to identify the worker who assembled the engine
« Last Edit: July 02, 2020, 06:12:35 PM by J_Speegle »
« Reply #6 on: June 08, 2014, 07:43:28 PM »
Thanks "Z", you did a great job!
Thanks everyone else. mystery solved :)
