Author Topic: 1966 convertible under hood paint color  (Read 1819 times)
Offline 69cobrajetrugae2
« on: June 07, 2014, 04:39:43 PM »
I am looking at a 66 convertible which is reputed to have 20K original miles. The underside of the hood is flat black, is this the factory color? Thank you in advance.
Re: 1966 convertible under hood paint color
« Reply #1 on: June 07, 2014, 05:11:06 PM »
it should be body color. check for date codes in lower corners where hinges are.
« Reply #2 on: June 07, 2014, 06:11:28 PM »
Thanks. One more thing. Did the factory install a 4 speed toploader or a T-10.  This one has a toploader.
« Reply #3 on: June 07, 2014, 06:12:36 PM »
toploader.
« Reply #4 on: June 07, 2014, 06:16:30 PM »
« Reply #5 on: June 07, 2014, 06:29:03 PM »
Wow. I think I have found a 30 year old restoration that has been driven.  It has the patina of an original car on the underside but I now believe that it is the second time around.  Thanks guys.
« Reply #6 on: June 07, 2014, 06:45:45 PM »
Due to a toploader transmission shortage, Ford also installed T-10 transmissions in V8 Mustangs for 1966 only, except HP. In 1965, the T-10 was not used on V-8 Mustangs, all toploaders. I don't know about 64.
« Reply #7 on: June 07, 2014, 08:47:45 PM »
+1.  Midlife (1966 GT fastback from NJ in early January) came with a T-10, and 10 years ago, I swapped it out with a correct toploader, never looked back.
BTW, the toploader came from Mustang Masters (Fast Freddy) at a reasonable price.
« Reply #8 on: June 08, 2014, 01:01:26 AM »
Thanks for all your help!
« Last Edit: June 08, 2014, 04:47:52 AM by 69cobrajetrugae2 »
