Author Topic: 69 radiator support to hood weatherstrip  (Read 1468 times)
Offline Buiaka
« on: June 03, 2014, 12:31:39 PM »
Dear all,
yes again the question about the radiator support to hood rubber. I always read that only 6 cylinders and big block mustangs had this.
My car is a july 1969 Metuchen built 351W-2V car with AC and power steering. Im not sure if i need this or if it was installed originally.
Thanks for help
greets
Christopher
Re: 69 radiator support to hood weatherstrip
« Reply #1 on: June 03, 2014, 09:48:55 PM »
First question should be - Does your car still have its original radiator support panel?
Are there any visible screw or staple holes across the top lip that might indicate that it had a hood to radiator support seal?
Would not expect that you will find any evidence that your car ever had the seal ;)
« Last Edit: June 03, 2014, 09:54:13 PM by J_Speegle »
Offline Buiaka
« Reply #2 on: June 04, 2014, 04:59:42 AM »
No signs of holes or even scratches. Looks original.
Thank you
greets
« Reply #3 on: June 04, 2014, 10:38:15 PM »
Did run across a fairly early 69 351 W with AC at the Resto-Mod shop today that did how signs of having a seal. Would have to see more examples that way (will keep an eye open for more) but its a different plant though wanted to mention it for other readers
Offline tony 63C
« Reply #4 on: June 05, 2014, 01:59:23 AM »
Also for the benefit of other readers, my San Jose 351W M Code (Oct 18, 68) Mach1 has the hood to radiator support seal.  This appears to be the original seal still held in by four of its five staples.
Cheers,
Tony
