Author Topic: RH Cowl Wire Clip Oct 64 San Jose  (Read 1632 times)
Offline ChrisV289
« on: May 21, 2014, 12:20:14 AM »
Which type of wiring clip was used on on the right hand cowl brace on an Oct 64 San Jose build?  Is it the small ones or the ones that hold the parking light wiring harness?
« Last Edit: May 22, 2014, 06:28:08 PM by J_Speegle »
2009 V6 Mustang Coupe
Re: RH Cowl Wire Clip
« Reply #1 on: May 21, 2014, 06:28:15 PM »
Right hand - guess that is the passenger side
It appears to be the sheet metal style of electrical clips like the one below
Offline ChrisV289
« Reply #2 on: May 21, 2014, 08:20:55 PM »
Thanks Jeff, that is what I assumed it was but wanted to be sure...
Offline rockhouse66
« Reply #3 on: May 21, 2014, 09:35:02 PM »
I have seen the clip that Jeff pictured on the radiator support to hold the wire there on the passenger side, but I thought the clips on the cowl brace were these smaller ones?
http://www.npdlink.com/store/products/clip_wire_harness_on_cowl_brace-143805-1.html
'66 GT FB
« Reply #4 on: May 22, 2014, 01:21:53 AM »
Jim: The small ones were not used at that time during SJ production... The K convertible had those gnarly things also.  I can only imagine how many mechanics lost skin on these!
Offline rockhouse66
« Reply #5 on: May 22, 2014, 08:33:05 AM »
Thank you Charles - I didn't realize there was an early/late thing on those clips.  I'm using the nasty small ones on my 9/65 scheduled SJ car which I assume are correct for that period?
'66 GT FB
Offline ChrisV289
« Reply #6 on: May 22, 2014, 08:35:51 AM »
One last question, one clip or two?
« Reply #7 on: May 22, 2014, 06:29:16 PM »
Oct 64 San Jose = 2
See those allot holding pillar light wiring for fastbacks in the trunk
The radiator support wire clip at the battery was a 66 fix to keep the wire from coming in contact with the top of the battery and the possible acid I believe
« Last Edit: May 22, 2014, 06:32:02 PM by J_Speegle »
Offline ChrisV289
« Reply #8 on: May 22, 2014, 08:11:48 PM »
Not to go to far off topic, but here are those clips Jeff was referencing in the trunk:
