I think $200 is probably a starting point for a simple R&R. If they find rust or if the glass needs to be removed, they will charge more.You probably would be best removing everything yourself. Clean the glue off the roof and then lay down some good catalyzed epoxy primer. Take the car up there after you do this and have them stick the vinyl top. I bet they would do it for $100 if you did it this way.
