Author Topic: Paint & Plating Finishes 4 70 Dearborn Boss 302  (Read 2375 times)
Offline skunk95
« on: May 08, 2014, 11:46:44 PM »
I have a 1970 Boss302 build in November 1969 in Dearborn. I need to know the paint & plating finishes for the following
Hood catch
Hood hinges
Tower/Export brace
Shock upper mounts
Upper Radiator support
Upper radiator saddle
Front sway bar
Rear sway bar
I know some are phosphate but don't know if its light, medium or dark. The black painted parts don't look the same as the engine bay paint in photos i have seen. not looking for this to be exact, just want to be close.
Graham
« Last Edit: May 10, 2014, 12:04:58 AM by J_Speegle »
Re: Paint & Plating Finishes 4 70 Dearborn Boss 302
« Reply #1 on: May 10, 2014, 12:57:16 AM »
Phosphate & oil for the following.  Mine always come out a medium color - careful on the heat and cooling with the hood springs
Hood catch
Hood hinges
Shock upper mounts
Shock Tower/Export brace - Slop gray (listed in the FAQ of this section of the site ;)
Are these not  the same parts? - Semi-gloss black
Both of the following semi- gloss black
Front sway bar
Rear sway bar
Offline skunk95
« Reply #2 on: May 13, 2014, 05:24:58 PM »
hi Jeff
thank you for your help, you are correct should have said Radiator Support and not Upper
graham
