Author Topic: The power steering control valve pinch clamp  (Read 1714 times)
Offline roddster
« on: May 07, 2014, 10:30:51 AM »
   The pinch clamp that holds the two power steering steel lines to the control valve.  Around here, near Chicago, there are no old Ford anything in the u-pick yards.  If you are lucky enough to find one, and pry it apart so you can reuse it, it will stress the metal so it will break the 2nd time you remove it.  These are really made for a one time use anyway.
  So, where does one find a suitable replacement?
Offline drummingrocks
Re: The power steering control valve pinch clamp
« Reply #1 on: May 07, 2014, 10:45:28 AM »
Good question.  I used a regular radiator hose clamp on mine until I can find something more like the original.  Can anyone post a picture of the original pinch clamp for comparison?  I figure most of these are long gone, and people now probably don't even realize the hoses were originally clamped to the control valve.
« Reply #2 on: May 07, 2014, 06:05:20 PM »
The one that goes around the lines and the control valve isn't a pinch clamp (like the ones at the ram boot or the cover at the ram) but a screw/worm style hose clamp
Will find a picture ;)
« Last Edit: May 07, 2014, 06:30:57 PM by J_Speegle »
« Reply #3 on: May 07, 2014, 08:03:06 PM »
Jeff ,the early 67 's used the same pinch type clamp around the control valve and lines as used on 65/66. The more conventional screw clamp started later in 67 production. Probably after the first of the year 67.
Offline roddster
« Reply #4 on: May 08, 2014, 10:39:54 AM »
  [  So, where does one find a suitable replacement?
[/quote]
  There are pinch clamps available.  But not from the usual suppliers such as NPD, AMK or Virginia Mustang.
   Anywhere else???
« Reply #5 on: May 08, 2014, 09:30:12 PM »
Thanks Bob for the reminder - Forgot about the early cars :(    67's - so much fun ;)
« Reply #6 on: May 08, 2014, 10:41:07 PM »
Yep, keeps us on our toes. ::)
