Author Topic: AC Compressor Rebuild  (Read 1865 times)
Offline 69eliminator
« on: May 05, 2014, 11:27:29 AM »
Can someone suggest how to test the compressor or a Vendor to send it to for testing / rebuilding? I am also looking for the mounting brackets if someone can suggest a supplier
Brian
1969 Cougar Eliminator 428 CJ Q Code with AC , PS, PDB, C6 Transmission,Traction-Lok Diff. 3.00. Bright yellow paint.
Dearborn 6/69
Offline suskeenwiske
  • 214-347-3628
Re: AC Compressor Rebuild
« Reply #1 on: May 05, 2014, 01:02:11 PM »
Classic Auto Air should be able to help you...possibly others, I just don't know their names.
They may also have the Bracket you're looking for.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline jimhib
« Reply #2 on: May 05, 2014, 02:17:44 PM »
   Provided you can spin the compressor shaft any reputable tech with a refrigeration manifold can tell you if its any good. The only thing I would really be worried about is the seal. The compressor if not left open to the atmosphere has a pretty good chance of being mechanically sound.
« Reply #4 on: May 05, 2014, 09:37:14 PM »
Thanks for the responses everyone.
I really appreciate the help.
Best,
Brian
« Last Edit: May 05, 2014, 09:39:04 PM by 69eliminator »
Dearborn 6/69
Offline TLea
« Reply #5 on: May 06, 2014, 08:39:30 AM »
Ray
+1 on Classic auto air. Make sure you tell them you want case left natural and I suggest you remove original tag and reinstall when it returns. Brackets are fairly common on Ebay or check with Scott at west Coast Cougars (he already answered this thread
