Author Topic: 66 shelby under ride traction bars  (Read 5503 times)
Offline kcodecoupe
« on: May 05, 2014, 08:22:13 AM »
what is the length and casting numbers on original 66 shelby under ride traction bars, thanks.
Re: 66 shelby under ride traction bars
« Reply #1 on: May 05, 2014, 09:06:38 PM »
Will have to find time to crawl under the wife's car for the length
Believe the casting on the end of the bar is "M1"  and each rear cast moutn has a series of numbers and a letter - will post a pic if I can. Of course these aren't Ford engineering numbers ;)
Offline zray
« Reply #2 on: May 05, 2014, 10:37:39 PM »
Just an FYI to the OP, the traction bar mounting bracket to the rear end is way different for the originals vs. the current product made by the  traction master co. What does your bracket look like, i.e. 4 hole bracket or 3 hole bracket, etc.
Z
« Last Edit: May 05, 2014, 10:41:50 PM by zray »
Looking for '65-'68 manual V-8 coupe
that doesn't need a new body
Offline kcodecoupe
« Reply #3 on: May 06, 2014, 09:34:17 AM »
The bars i purchased have the M1 casting are 22 inches hole to hole 23 1/2 total length and have a slight curve on each one at the rear of each bar ,
« Last Edit: May 07, 2014, 11:38:56 AM by kcodecoupe »
Offline zray
« Reply #4 on: May 06, 2014, 11:13:39 AM »
The bars i purchased have the M1 casting are 22 inches hole to hole 33 1/2 total length and have a slight curve on each one at the rear of each bar ,
They are known for bending when subjected to dragstrip conditions.
The last '66 GT350 I owned had the traction bars braced with a long strip of steel that was welded to the tube by the original owner. He raced it A LOT in the streets of Juarez Mexico to raise $$$ to help pay for college.
Z
Offline kcodecoupe
« Reply #5 on: May 06, 2014, 01:46:10 PM »
Z
I had thought that too but these both have the exact same curve in them, im not even sure they are shelby bars or for another application,
« Reply #6 on: May 06, 2014, 11:31:28 PM »
I came up with approx 26 1/2" total length or there about
M-1 cast into the end
Mounts look like these two (Correct finish rather than my choice 30 yrs ago :(
Offline kcodecoupe
« Reply #7 on: May 07, 2014, 11:47:18 AM »
Thanks for the info and posting pictures , looks like the bars i picked up at the swap meet are not shelby bars as they are 3 inches too short.
Offline zray
« Reply #8 on: May 07, 2014, 03:45:46 PM »
How about the ends ?  Are they cast with the M-1 ?  And the end plates ,  are they 3 hole type as  J. S. posted ?
If so, they might Shelby bars that some one modified for another application,
Z
Offline sgl66
« Reply #9 on: August 19, 2014, 11:20:56 PM »
Just came across a set in my spare parts with 1068 LH cast in them...both LH. strange collection I acquired with the car 30+ years ago.
Pulled a set with 10-70 off car with bent bars.
« Reply #10 on: August 20, 2014, 02:45:21 PM »
There is a version of the override bar that had a curve built in to clear a bolt .I do not have access to my not to see if the length you gave would indicate it was one of those or not.
« Reply #11 on: August 20, 2014, 05:49:39 PM »
"Bent" bars could also be the twisted current state we find many in - from either heavy use or one or two too many floor jacks being placed on them :(
