Author Topic: 1970 Dearborn Mach1 Fender Extension Black Out?  (Read 2137 times)
Offline 70machwun
« on: May 03, 2014, 01:30:13 AM »
Hi, I have seen a few pictures of the fender extensions on what I believe are Dearborn built 1970 mustangs blacked out behind the grille area.  I'm wondering if this is correct.  I have a Dearborn built 1970 Mach1, yellow, built 4/70.   Any insight on what areas either behind the grille, headlight bucket or both should be blacked out and what application method, sprayed or brushed, is much appreciated.
Steve
« Last Edit: May 03, 2014, 04:38:15 AM by J_Speegle »
Re: 1970 Dearborn Mach1 Fender Extension Black Out?
« Reply #1 on: May 03, 2014, 04:44:16 AM »
Fist welcome to the site hope you find the things you need finish your concours car
Its not a Mach I thing like the side (door, fender & quarter panel) or taillight panel black out is.
I thought we had already covered this in another thread here since we opened - but guess what I'm recalling was one of the other sites I've posted the pictures and details to. Guess its time to do it here also.
Getting late here - so will post them tomorrow. Just wanted you to know someone saw the thread and responded
Again welcome
Offline 70machwun
« Reply #2 on: May 03, 2014, 03:58:35 PM »
Thank you Jeff. Glad I found this site.
Steve
« Reply #3 on: May 03, 2014, 06:31:22 PM »
Here you go  - hope this helps
« Last Edit: November 16, 2017, 04:35:17 PM by J_Speegle »
Offline 70machwun
« Reply #4 on: May 03, 2014, 07:27:22 PM »
Thank you Jeff, very helpful!!  Definitely looks like that was sprayed on and looks like a satin sheen, like the engine compartment.
Steve
« Reply #5 on: May 03, 2014, 07:31:58 PM »
Yes applied before they were bolted to the fender. Not sure of the sheen - after all these years of exposure :(  But very likely something in the semi-gloss black range of things
