Author Topic: 69/70 convertible power top fuse  (Read 8087 times)
Offline SCJSTU
« on: March 09, 2010, 02:55:03 PM »
Can someone shoot me a picture of what the fuse block by the starter relay( for the convertible top power) looks like.....
mine has the older style fuse juntion block...I have the correct fuse block now so need to see how its mounted..
thanks,
stuart@cofers.com
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
Re: 69/70 convertible power top fuse
« Reply #1 on: March 09, 2010, 06:12:48 PM »
Do you mean fusable link? Bob
Offline SCJSTU
« Reply #2 on: March 09, 2010, 09:17:34 PM »
oops I mean the circuit breaker for the power top.........it is attached to the side of the starter relay somehow...thats what I am trying to fig out as mine is wired wrong and trying to put back the correct way....
Offline SCJSTU
« Reply #3 on: March 10, 2010, 08:02:43 AM »
ok....starting to see why I am confused...
I have 2 1970 convertibles
the 351W Oct built Met car  has a circuit breaker like this installed which appears is wrong
http://www.scottdrake.net/prod_details.aspx?prod_id=1856&breadcrumb=Convertible+Parts+%3a%3a+Electrical+%3a%3a+Convertible+Top+To+Switch+Circuit+Breaker
my 1970 351C June built Dearborn car does not have it but the owner had to straight wire it because the fusible link was bad?.......just got the car so trying to fix the prob.....but trying to fig out how to do correctly...
Offline SCJSTU
« Reply #4 on: March 10, 2010, 08:58:37 AM »
The Osborne 1970 Mustang Electrical manual pg 37 shows the circuit breaker but I have been told this is wrong?
it shows using this breaker....
« Reply #5 on: March 10, 2010, 11:31:15 AM »
The circuit breaker will work but is not what came on the assemblyline. The fuseable link is what was used on the Dearborn cars i am familiar with. It connected inline (plugged in) with the harness coming out of the firewall. The short link had a plug on one side and a terminal on the other end that connected to the power side of the starter solenoid. It is short about 6 inchs if I remember. I will try and remember to take a picture today.I think there is a repro source for them but can't remember where I saw it . I always try and use originals because they have a slightly different look. Bob
Offline SCJSTU
« Reply #6 on: March 10, 2010, 01:06:10 PM »
Thanks Bob....
I have had 3 1970 convertibles in last 3 years and all 3 used the inorrect circuit breaker setup so thats why I am confused.....
if you think of the source for the fuse link that attaches to the relay please let me know....
Scott Drake and the parts houses do not......
Stuart
« Reply #7 on: March 10, 2010, 02:55:05 PM »
I just remembered and can't believe I forgot my friend Pete disher  www.thecoralsnake.com  . Go to his website and click on for sale. He sells all kind of wiring  including the convert power lead to the solenoid for 69/70. I don't know if you sells just the fusable link but wouldn't be surprised if he did. Bob
« Last Edit: March 10, 2010, 03:19:13 PM by Bob Gaines »
Offline SCJSTU
« Reply #8 on: March 11, 2010, 02:24:04 PM »
Bob and all,
could you take just a moment and read my thread over on VMF about this?
http://forums.vintage-mustang.com/vintage-mustang-forum/610839-1969-70-convertible-question.html
I am always a doubting thomas on these things....
It sure does look like my circuit breaker setup is original to my car but of course can't prove on a 40 year old car....
My car is a very late build.....June 1970....I am told all 70 convertibles built at Dearborn....
so maybe my convertible top wiring was a late change? My wiring is uncut from starter relay back thru firewall...
my option with the convience group may be a clue as another person on VMF posted the same wiring I have from his car......
« Reply #9 on: March 11, 2010, 03:26:54 PM »
It reads like the the fuselink is what others have found . I will be the first to admit I am not the best on 70 Mustang assesories as my experience is in the Shelby area where the 70 version is a updated 69 model. 69 I am 100% sure. 70 less then that. Bob
Offline SCJSTU
« Reply #10 on: March 12, 2010, 12:56:14 PM »
Bob,
....question about the Osborne assembly manuals......you know pg 37 of the 1970 Electrical Assembly Manual that shows the circuit breaker being used instead of a fusible link has a revison date of
12-23-69 and says it supercedes 11-24-69 effective with CZY1-RD-5222222
my cars build date is June 1970
maybe assume that it might have taken several more weeks for this revision to show up on the plant floor...........so maybe the circuit breaker is correct for a 70 convertible build Feb 1970 on?
« Reply #11 on: March 12, 2010, 06:19:44 PM »
Checked through my pictures and not much there,
This is from a 70 (170000 range) convertible - unfortunately, restored
Offline SCJSTU
« Reply #12 on: March 12, 2010, 07:57:39 PM »
my vin is in the 190000 range
here is my setup before I corrected the wire in wrong place....
it does have the circuit breaker on the back side.........
« Last Edit: March 12, 2010, 08:03:36 PM by SCJSTU »
« Reply #13 on: March 13, 2010, 12:08:47 AM »
I would check with Pete and see if he has the breaker version of the wiring. Bob
