Author Topic: Thermostat housing, Early 65 FB  (Read 4123 times)
Offline vinny
« on: May 01, 2014, 04:15:03 PM »
Looking for a thermostat housing for 65 FB 289.. Build date Oct 64.. Therefore it needs to be a housing with no recess for thermostat. No chrome please. Cast aluminum only. Thanks
Re: Thermostat housing, Early 65 FB
« Reply #1 on: May 01, 2014, 08:14:26 PM »
Vinny,
 You need a cast iron water outlet, not aluminum. Aluminum was only used on 289 HP engines. It's still without the tapped hole on top.
Offline Richard P.
« Reply #2 on: May 01, 2014, 09:20:06 PM »
The aluminum water outlet housing was used on the 289 A, C, D and F code engines. It was not unique to the HP engine only.
Offline Richard P.
« Reply #3 on: May 01, 2014, 09:21:37 PM »
Sorry that should be 260 F code engine.
Offline vinny
« Reply #4 on: May 04, 2014, 03:21:10 PM »
Hello , thanks for the responses. It sounds like an aluminum was only used on HIPO engines? And that i need a cast iron housing without the thermostat recess and without the tapped fitting on the top? I have 2 part numbers.. C4OE-8592A or C3OE-8592A. Or should i get a C5OE-8592A? I thought the C5 housing was when they incorporated the recess in the housing and removed the recess from the intake. Any help in locating the proper one would be appreciated. These things are hard to find.. All i can seem to find are the recess in the housing part..
Offline vinny
« Reply #5 on: May 10, 2014, 11:36:32 PM »
Thermostat housing found and bought..Thanks for the read..
Offline Richard P.
« Reply #6 on: May 10, 2014, 11:48:04 PM »
Did you find a cast iron or aluminum housing?
Offline vinny
« Reply #7 on: May 10, 2014, 11:50:13 PM »
aluminum..It was actually the c4oe part .. with no recess.
Offline Richard P.
« Reply #8 on: May 12, 2014, 01:56:02 PM »
That's what I thought. Aluminum
« Reply #9 on: May 12, 2014, 08:20:08 PM »
I've never heard of a cast iron t-stat housings used on 65-66 289 motors.
Offline livetoride60
« Reply #10 on: May 13, 2014, 12:10:43 AM »
Original C4OE from my Oct 64 SJ hipo, no recess for thermostat.  C4OE-8594-A is the full number according to Bob Mannel's book.  Aluminum.  The book does not say they are unique to hipo's.
« Last Edit: May 15, 2014, 08:19:32 PM by livetoride60 »
« Reply #11 on: May 13, 2014, 10:46:28 AM »
+1, haven't heard of a unique hi-po t-stat housing.  Would be interested in learning where that information was found?  Maybe start a new topic in main forum?
Offline Richard P.
« Reply #12 on: May 13, 2014, 06:48:09 PM »
+ 1
« Reply #13 on: May 14, 2014, 01:10:03 AM »
+1
Offline zray
« Reply #14 on: May 15, 2014, 05:27:24 PM »
also unlikely since the HiPo used the same intake manifold as the A & C code cars.
Z.
Looking for '65-'68 manual V-8 coupe
that doesn't need a new body
