Hi guys, some of you might have seen or participated in my earlier thread about Concours Driven and my '69 Mach 1. It's an M-code, so it would've come with an Autolite 4300 originally. Since the original carb was long gone when I got the car, I replaced it first with a 600cfm Edelbrock, and later with a 600cfm Holley. The Holley is on the car now, and while it runs light years better than it did with the Edelbrock, I'm still not 100% happy with it. No matter what I do, I end up with a slight binding feel in the gas pedal. I've tried two of the best quality throttle cables from NPD, have removed and greased both the cable and the gas pedal assembly inside the car, and have modified an extra throttle bracket to ensure the cable is traveling straight. All of this, and I'm still not happy.
I thought about trying to track down the correct 4300 for this car, but from everything I've heard and read, the 4300 is not the greatest design in the world, and is nowhere near as well thought of as the 4100 (which is on my '66 fastback, and is great). I generally use a local, well-known carburetor guy for my carburetor rebuilds, and he told me to stay away from the 4300. He was a Ford/dealership mechanic back in the late 60s and early 70s, and he said that those carburetors were junk when they were new. He said it go to be so bad that when the dealership called Ford about a warranty issue with a defective carburetor, Ford gave up trying to troubleshoot the issue or walk the tech through fixing the carburetor and instead began sending out entirely new 4300's. Apparently some of these carburetors ran "ok," and some just absolutely refused to run well, and Ford's recommendation was to try another when the original failed. Are these carburetors really THAT bad?
With that being said, I've read online that Pony Carbs claimed to have fixed most of the well-known issues associated with the 4300. Can anyone comment on that? I'd hate to drop $400-500 on a show-ready carburetor, only to have it be an expensive paperweight. However, I know that the throttle linkage was designed for the 4300, so presumably it will work well with it, AND I'd get some points back if I show in Concours Driven. Anyone care to offer any advice about what to do?
Thanks!
