Author Topic: where to buy plastic speedometer cable clip (center of firewall)  (Read 2815 times)
Offline martin
Need the plastic clip which attaches the speedometer cable to the center of the firewall.
Anybody know where to buy these
69 mach 1 390 toploader
built at San Jose Oct-25-1968
Offline svo2scj
Re: where to buy plastic speedometer cable clip (center of firewall)
« Reply #1 on: April 27, 2014, 09:51:22 PM »
I don't think that was plastic.   It is one of those items you can't BUY (easily from your chair with a credit card)!
You are going to need to find a used one.  I'm sure someone here has one.
Mark
« Reply #2 on: April 28, 2014, 12:57:15 AM »
Martin - maybe you can post a picture showing where the clip goes as well as what trans, when and where your car was built. Many of the clips on the firewall are different depending on where your car was built
You'll find that adding your cars info to your signature can save allot of time - or your going to be answering the request for when and where in almost every post ;)
« Last Edit: April 28, 2014, 01:00:02 AM by J_Speegle »
« Reply #3 on: April 28, 2014, 11:54:28 AM »
http://www.concoursmustang.com/forum/index.php?topic=6998.msg39590#msg39590
     The photos posted by Wade 429 very clearly show two different clips.  One for the speedo and one for the 4 speed reverse wire harness.  Are these two plastic clips correct ?  Where to get them ?  Brian
Offline martin
« Reply #4 on: April 28, 2014, 12:34:09 PM »
Those exactly what i am searching for. I need both aswell.
« Reply #5 on: April 28, 2014, 01:48:09 PM »
The one shown in the very last picture (deadnutson pic) at the bottom is different depending on when and where the car was assembled
Of course this is showing a manual transmission application ;)
« Reply #6 on: April 28, 2014, 03:11:18 PM »
I have looked around the Deadnuts site and cannot find these pictures.  What car did these photos come from ?  Not from a 69 SCJ Mustang.  Brian
« Last Edit: April 28, 2014, 03:14:13 PM by Brian Conway »
« Reply #7 on: April 28, 2014, 03:17:16 PM »
Just guessing but remembering what Jack has taken pictures of and shared with me in the past I would guess its a 69 Dearborn GT500
« Reply #8 on: April 28, 2014, 04:45:18 PM »
Thanks Jeff; some of the stuff in there doesn't look familiar.  No shock tower reinforcement.  Maybe a 350 or a small block 69 ?  Brian
« Reply #9 on: April 29, 2014, 05:06:37 PM »
Correct - didn't look at the pictures carefully enough.
Its a spring 69 Dearborn Boss 302 - if that relates to the OP need or car
