Author Topic: C4zf fuel sending unit  (Read 1023 times)
Offline 65fastbk
« on: April 24, 2014, 12:12:32 AM »
Hi,
I have a c4zf fuel sending unit that needs to be recalibrated or restored. Does any on recommend anyone?
Thank
Offline 65fastbk
Re: C4zf fuel sending unit
« Reply #1 on: April 26, 2014, 12:15:17 PM »
Hi,
Are these not worth restoring, I don't see anyone restoring them or people talking about fixing them:)
thanks
« Reply #2 on: April 26, 2014, 03:49:53 PM »
The two most common failures in the fuel sender are leaky floats and the resistance wire being rubbed by the arm that it opens up giving a bad reading. Float replacement is easy, the resistance wire is not. As far as I know there is no direct replacement for the wire, but I've seen the entire resistance wire/flat subassembly replaced with a later version. That keeps the marking on the seal plate, and that's about the extent of restoring.
