Author Topic: Fan Shroud Brackets  (Read 3233 times)
Offline suskeenwiske
  • 214-347-3628
Fan Shroud Brackets
« on: April 14, 2014, 09:06:49 PM »
I recently found a '65 6-Cylinder Fan Shroud but am still in need of the Brackets. If anyone has a set they would like to sell or if not for sale, would someone consider lending them to me or be willing to trace the Brackets onto paper so that I can make my own set?
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline Colorado56
Re: Fan Shroud Brackets
« Reply #1 on: June 09, 2014, 10:00:03 PM »
Did you ever find any brackets?  I am in need of a set as we'll.
Thanks, Dave
  • 214-347-3628
« Reply #2 on: June 12, 2014, 01:15:15 AM »
I didn't find any but another member was kind enough to send me one of his originals. So far, I have made one copy as I experiment with different processes to make these. I'm making one for him and four for myself.
Once I figure out the best way to reproduce these I may make more for other people in need. At this stage however, it's far too time consuming to do entirely by hand. I'm in the process of making a jig for the bends and a rudimentary dye to produce the threaded hole. First I need to make one more to use as a model so I can return the original and a copy to the person who lent me his. If successful, I will contact you and would be more than happy to make a set for you.
I've attached a few photos. My reproduction is identical to the original but has some tool marks that are unavoidable; the next few, through the help of the jig, should do away with that.
Ray
« Last Edit: June 12, 2014, 03:11:19 PM by suskeenwiske »
Ray
1965 Dearborn Coupe
Est. Build 23A
« Reply #3 on: June 12, 2014, 02:18:15 PM »
Nice work Ray. It is good to see some of the tough parts being reproduced for the 6 cil. cars.
  • 214-347-3628
« Reply #4 on: June 14, 2014, 12:38:02 PM »
Thank you. There are other parts that I'm looking into for the six that no one reproduces; Metal Strap for AC Hoses, (same for 8 Cyl.) and Rubber Damper for the Accelerator Linkage.
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
Offline C5ZZ
« Reply #5 on: June 14, 2014, 03:07:43 PM »
Very nice work Ray!
MCA # 00945
Rangoon Red/Red Interior
« Reply #6 on: June 14, 2014, 07:28:48 PM »
Ray
I reproduce the C8OA - 18954 - A metal clamps if that is what you are looking for. I just bumped them to the top of the For Sale section.  I also may have the rubber damper you are looking for.
Marty
« Last Edit: June 14, 2014, 07:37:04 PM by ruppstang »
  • 214-347-3628
« Reply #7 on: June 15, 2014, 12:02:31 AM »
Thanks Marty. I already have 2 of the Dampers; one is so perfect that, I can use it as a Template to make others. The Strap I'm talking about attaches to the Firewall / Shock Tower Brace. I just received one in excellent condition from which I can reproduce others.
I also need to make a correction to my last post. The Strap is not the same for 6 and 8 Cylinders. The 8 Cylinder Strap is shaped to hold two AC Hoses; the 6 is shaped to hold just one. To the best of my knowledge this applies for the pre-'67 models. Not a great picture...sorry.
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
« Reply #8 on: June 15, 2014, 08:46:08 AM »
I forgot you were talking about 65-66s I was thinking 67-68.
Sorry Marty
Offline Colorado56
« Reply #9 on: July 10, 2014, 01:51:46 AM »
Ray,
keep me posted on the brackets.  I am in for a set if you get the process down to make them.
Thanks, Dave
  • 214-347-3628
« Reply #10 on: July 11, 2014, 10:45:46 AM »
Dave,
I've since been informed that Classic Auto Air makes reproduction Brackets for the six that I understand are exactly as the originals. I plan to buy a set to see for myself. I'll let you know what I find.
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
Offline Colorado56
« Reply #11 on: July 14, 2014, 04:28:58 PM »
ordered a set from Classic Auto air.  Thanks for the info
Dave
