Author Topic: How do I keep the rear license plate from scratching the paint?  (Read 2079 times)
Offline blk65fstbk
I'm getting down to the small details now.
I went to install my rear license plate and found that the back of the plate was going to be in contact with the surface of the paint (horizontally across the middle of the plate). Does anybody have a good solution to keep the plate off of the paint? Gasket, film, etc.?
Thanks.
1965 Mustang Fastback
"A" Code 289 V8, 4 Speed Manual Toploader and 3.00:1 Locking Differential
Raven Black Exterior and Black Standard Interior
No PS, PB or A/C
Built November 5, 1964 in Dearborn, MI
Offline suskeenwiske
  • 214-347-3628
Re: How do I keep the rear license plate from scratching the paint?
« Reply #1 on: April 12, 2014, 01:18:04 PM »
I purchased some 1/4" foam Weatherstripping from a hardware store that has adhesive on one side. It easy to hide and soft, so it doesn't make it difficult to attach the plate to the car. I've also had luck using Stainless Steel Washers on the bolts to create a slight gap between the plate and the body...along with the foam.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
« Reply #2 on: April 12, 2014, 02:00:06 PM »
Sometimes you can bend the plate very slightly to keep the edge away from the part. Other than that on a concours cars I would leave it as is  or Place a bumper (strip of weatherstrip, foam tape ....) behind it and remove the plates for showing
