Author Topic: 66 A code NJ - Engine Decal placement  (Read 2926 times)
Offline 66RavenGTCoupe
« on: April 06, 2014, 09:32:35 PM »
Hi all,
I thought I would start this thread here as I figured that different workers in different plants may have placed some of these decals differently.
It would be great if some original car photos could be posted up on here for us all to see. The ones that are mainly in question are the air cleaner decals if anyone can help. My car was built on 7th Dec 65 so anything around there would be great.
Dan.
« Last Edit: April 07, 2014, 09:57:44 PM by J_Speegle »
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Re: 66 A code NJ - Engine Decal placement
« Reply #1 on: April 07, 2014, 10:39:57 PM »
Checked my pictures and all the best examples are from April to the end of production :(
« Reply #2 on: April 08, 2014, 07:12:29 PM »
I would not mind seeing the earliest (April) ones for locations if you could Jeff.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #3 on: April 08, 2014, 08:40:34 PM »
I have a MAR 15 66 Metuchen Conv't.  Jeff helped me confirm a couple years ago that the silver decal on the right shock tower in-fact, goes vertical so you can lean over the fender and tilt your head to read it.
The air cleaner DID NOT have the arched Autolite decal on top.  It had the rectangular one on the left side.
MY 289 2V decal has orange/black checks and NOT white/black.
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #4 on: April 08, 2014, 09:48:16 PM »
Hey there bryancobb,
Thanks for your response. I can second the positioning of the sliver decal as I had that one and made a template of it's position. It too was greatly skewed down on the left side from a vertical position (Starting at 7 o'clock position) I also had the clear remains of the glue of the Autolite straight decal on the drivers front side of the air cleaner and not a curved one on top. Mine is a 298 4V so I have the white/black checks on the 289 premium fuel decal.
Was mainly wondering about the "part number", "genuine parts", "front" and "crankcase ventilation" decals.
Can anyone help me on any of these four?
Thanks in advance,
Daniel.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #5 on: April 08, 2014, 11:02:37 PM »
Ok will throw these out there for you to evaluate and apply what you feel comfortable with ;)
Don't think there was a FRONT used - more likely the filter part number in that location as one of the pictures show and nothing on the valve/breather cap
As mentioned - didn't find anything on the lids except the CU In decal the one on the side replaced the one at the back on the lid
Hope this helps - did have to throw in a bunch of C codes but believe that they are pretty much the same pattern
6T07C15953x
6T07C18385x
6T07C26694x
6T07C26694x
6T09C2860xx
6T09C24357x
6T09C28607x
