Author Topic: 64.5 steering gear box pictures  (Read 2528 times)
Offline CW4macret
« on: April 05, 2014, 08:05:01 PM »
I just started cleaning the steering box from my D code. Took some pictures of what I found under all the dirt.
Mac
64.5, 5F07D
66 Convertible 6T08T
71 Mach1 429CJ 1F05J
01 Coupe
05 GT
08 GT500
14 GT500
Offline suskeenwiske
  • 214-347-3628
Re: 64.5 steering gear box pictures
« Reply #1 on: April 05, 2014, 10:48:38 PM »
Thanks...always great to see another example of paint markings. For the record, which factory built your car?
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
« Reply #2 on: April 06, 2014, 01:16:18 AM »
Another blacked out top steering box.  The pace car coupe I'm assembling also had a blacked out top.  It has a different lock ring, cast part instead of stamped, kind of a pain to get it tight.
Offline CW4macret
« Reply #3 on: April 06, 2014, 10:32:06 PM »
Dearborn :)
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
« Reply #4 on: April 07, 2014, 09:52:38 PM »
PS box??
Offline CW4macret
« Reply #5 on: April 08, 2014, 02:17:59 PM »
No this a very basic D code. No PS, PB or AC. Generator of course
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
« Reply #6 on: April 08, 2014, 03:28:35 PM »
Thanks - since different boxes would get different marks ;)
Offline Hipo giddyup
« Reply #7 on: April 08, 2014, 05:21:50 PM »
  How would the "black out " be applied and when?? With the steering box in the car or when the box was completed from the assembly plant?? Curious as it looks like it is also all over the side facing the engine.
Offline CW4macret
« Reply #8 on: April 08, 2014, 06:37:51 PM »
Interesting question. At first I thought the black was just some rattle can someone used to dress up the engine compartment. In fact the column housing in the engine compartment is black also. (blue interior and blue column inside). Anyway the black on the cap seems to be better quality and too thick to be spray can in my experience. Car had 37000 miles and motor was standard bore so I do not think it had been out before.
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
« Reply #9 on: April 08, 2014, 06:45:01 PM »
Interesting question. At first I thought the black was just some rattle can someone used to dress up the engine compartment. In fact the column housing in the engine compartment is black also. (blue interior and blue column inside)...........
You might have both things going on in your compartment - original brush on and PO rattle can.
Offline CW4macret
« Reply #10 on: April 11, 2014, 03:07:46 PM »
So are you say the box and column should be black on a 64.5?
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
« Reply #11 on: April 11, 2014, 03:10:11 PM »
no. the exposed column in the engine compartment is the same color as the interior of the car. the top of the box may be blacked out depending on production date/plant.
