Author Topic: Steering Column Bearing  (Read 1115 times)
Offline suskeenwiske
  • 214-347-3628
« on: April 01, 2014, 12:43:23 AM »
Just curious if anyone has had any experience with one Bearing over the other in terms of Durability, Noise, etc.?
Also, any Lubricant recommendations for the Bearing?
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Re: Steering Column Bearing
« Reply #1 on: April 01, 2014, 12:52:09 AM »
I'd use the metal one, wouldn't want a plastic bushing binding and possibly breaking inside of there.
Regular lithium grease is all that is required.
Offline Rsanter
« Reply #2 on: April 01, 2014, 02:15:40 AM »
Is the metal one original and the plastic a repo?
I only remember seeing the metal ones in the cars I have worked on
Bob
Bob
68 mustang conv basket case
69 mustang conv 302 AT
  • 214-347-3628
« Reply #3 on: April 01, 2014, 03:16:10 AM »
As far as I know, the Metal Sleeve is original; the Plastic a Replacement. I believe that Ford originally made this Replacement and is what is now Reproduced...I may be incorrect. Can anyone shed some light on this?
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
« Reply #4 on: April 01, 2014, 10:06:15 AM »
I've only ever seen the metal ones.
« Reply #5 on: April 01, 2014, 12:38:53 PM »
NOS Ford Bearings are nylon and were sold under p/n B1AZ-3518-A in a package of four. The full name is Steering Column Bearing Sleeve, abbreviated on the package. I agree with Charles about using a metal one instead of the nylon type, but mostly for originality than reliability. I only used one on a car with a lot of lithium grease.
