Author Topic: Coil Brackets  (Read 3263 times)
Coil Brackets
« on: March 25, 2014, 12:31:25 PM »
Can't find where these have been documented.
The bottom two are basically the same with the opposite corner cut. I think the left bottom is 1968, right bottom is 1967 and possibly 1970?
Top left is 1969 351W.
I believe that there maybe even one more found on 1967-73 V-8 engines. MPC is kind of confusing for applications. 1-2, 3? for 1970? May have to do with where the coil is mounted?
Thanks is advance!
Re: Coil Brackets
« Reply #1 on: March 25, 2014, 01:03:07 PM »
     FWIW.  This is the type that is on my 69 car.  Brian
« Last Edit: March 25, 2014, 02:54:39 PM by Brian Conway »
Re: Coil Brackets
« Reply #2 on: March 25, 2014, 01:04:28 PM »
There's another variety with a hole to index the coil and also 6 cyl are different.
Re: Coil Brackets
« Reply #3 on: March 25, 2014, 09:41:14 PM »
Believe different corners angled = big block - small block applications
There are also reinforced and unreinforced versions as well as the early and 6 cylinder versions as Charles mentioned
Guess this subject is going to take a while. ;) Let me dig through the pictures and start posting what I find while others post their findings.
Sure everyone understands how often these brackets can get swapped from one car to another especially when they are rebuilt or the engine gets swapped ;)
Re: Coil Brackets
« Reply #4 on: March 25, 2014, 10:24:58 PM »
........ or the coil gets replaced with used.
Offline carlizard
Re: Coil Brackets
« Reply #5 on: March 25, 2014, 11:07:12 PM »
Just finished cleaning and refinishing the coil bracket for my 1964.5 260 V-8 Vert.  See attached. Chuck
1964.5 260
Body:   76A
Color:   M
Trim:    89
Date:   30G
D.S.O:  75
Axle:    1
Trans:    6
Offline fast66
Re: Coil Brackets
« Reply #6 on: March 26, 2014, 03:19:33 AM »
Believe the cut corners may refer to where the coil was placed on the engine. Ie Chucks 64½ is for an intake mounted coil - if you would mount one on the right head of a 65/66 it would need to be cut in the other corner.
br
Claes
6T09K212784
63A 4 25 21B 951384 5 6
Offline carlizard
Re: Coil Brackets
« Reply #7 on: March 26, 2014, 05:32:13 AM »
You're exactly right.  The notch allows the coil to fit up against the intake manifold and sit parallel to the valve cover centered under the vacuum advance.
1964.5 260
Body:   76A
Color:   M
Trim:    89
Date:   30G
D.S.O:  75
Axle:    1
Trans:    6
Re: Coil Brackets
« Reply #8 on: March 26, 2014, 10:59:07 PM »
Not sure if this is going to work with all the different years and applications
Just a thought
Offline poboy427
Re: Coil Brackets
« Reply #9 on: June 16, 2014, 11:49:18 PM »
Coil taken from '68 Mustang V8. Build factory unk. Coil tension screw has "L" stamped on the head. With the grease and crud on the bracket and yellow top would seem to suggest an original rather than replacement piece. I don't think this engine ever saw a pressure washer either! As you can see no index hole in bracket either.
Ray
