Author Topic: Strut Rod > Lower Control Arm Bolt Head Markings  (Read 1258 times)
CobraSpeed
  • Guest
« on: March 22, 2014, 01:05:25 PM »
« Last Edit: May 19, 2020, 05:12:21 PM by J_Speegle »
Offline suskeenwiske
  • 214-347-3628
Re: Strut Rod > Lower Control Arm Bolt Head Markings
« Reply #1 on: March 22, 2014, 06:32:52 PM »
This is the original Nut and Bolt from my '65 6-Cylinder Dearborn Coupe, January 1965. The Reproduction Bolt Head is close but lacks the Ring at the outer edge and their Nut is nowhere near the same. I've seen your Bolt as well on other Mustangs and may be correct for 8-Cylinder cars or possibly different based on the Supplier, Running Changes, when Built, which Plant, etc. Hopefully someone else can add clarification; I'm no where near expert enough for this kind of detail.
Thanks for posting.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
« Reply #2 on: March 22, 2014, 08:32:54 PM »
Those bolts, 379779-S8, came in grade 6 and grade 7. My Oct 65 San Jose "K" Fastback has (and had) grade 6 bolts. As long as all four are the same grade on your car you should be OK.
« Reply #3 on: March 23, 2014, 01:14:57 AM »
I've seen that same bolt on many '64 1/2 - '65 cars.  As Jim says, both were probably used.  If one is certain that the bolts have not been changed, then they can be re-plated.  Those were typically clear zinc.
  • 214-347-3628
« Reply #4 on: March 23, 2014, 01:26:54 AM »
+1 on the Zinc. My Bolts still have some of the Zinc clearly visible.
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
