Author Topic: Firewall Hole locations and sizes  (Read 4046 times)
Offline 1966GTFB
« on: March 21, 2014, 04:07:02 PM »
Help please.
I have an original early 66 GT FB SJ car mid Sept 65. The old Firewall was replaced and now I am trying to put it back together. It has a 65 washer pump 2 wire harness with the large grommet through the firewall but there is no hole for that to fit on the new FW. Photo attached.
1)What size should it be to fit the 65 harness? I had another look at the plug, it appears to be 3/4 does that sound correct? If anyone can confirm that would be appreciated.
2) Where does the Fog light feed come through the FW?
Any idea what the small hole up and left of the headlight harness is for?
Thanks everyone.
Jeff
« Last Edit: March 23, 2014, 02:09:16 PM by 1966GTFB »
SJ Build Date: 9/17
'66 Fstbk: 63A X 26 17J
Offline Brian Conway
Re: Firewall Hole locations and sizes
« Reply #1 on: March 23, 2014, 04:29:58 PM »
Hello Jeff;  Surprised the guys have not gotten to your questions.  My ride is a May 65 SJ car.  Couple of pics to get you going.  the GT/fog light wire is the smaller of the two and is a bullet connection.  The larger wire is for a alarm system.  Will be back with particulars later.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
« Reply #2 on: March 23, 2014, 06:08:51 PM »
Remember my car was delivered to the new owner on May 29, 1965 and scheduled for June 1.  My car does not have a windshield washer but I assumed the small hole was for that set up.  Took a picture of the area and there is another dimple there for something ?  The GT fog light wire hole is 7 1/2" down and 1 1/8" over.  Brian
San Diego, Ca.
Offline 1966GTFB
« Reply #3 on: March 23, 2014, 07:05:22 PM »
Thanks Brian, The measurements are from the cowl I assume?
Jeff
SJ Build Date: 9/17
« Reply #4 on: March 23, 2014, 07:29:39 PM »
Yes.
San Diego, Ca.
Offline 1966GTFB
« Reply #5 on: March 23, 2014, 08:58:01 PM »
Thanks again Brian, Can anyone confirm the wiper location and size. It looks to be ~3/4 straight above the headlight harness but how much above I wonder?
Jeff
SJ Build Date: 9/17
« Reply #6 on: March 25, 2014, 12:06:05 AM »
Hello Jeff;  Surprised the guys have not gotten to your questions.............
Been doing a bunch of car inspections, phone calls and writing reports this week
To the request
Here are two pictures from that plant and period showing the holes and plugs and wires depending on application (GT or non GT)
Last picture is from a car much later in 66 around 159xxx. Hope this helps
Offline 1966GTFB
« Reply #7 on: March 25, 2014, 06:56:10 PM »
Perfect, that is what I thought, Do you happen to know the size the Washer harness hole for '65 plug Jeff? I bet you do?
Jeff
SJ Build Date: 9/17
« Reply #8 on: March 25, 2014, 09:44:53 PM »
No 65's at home but can see if there is one or more 65's at the Resto Mod shop tomorrow- its shop day :)
« Reply #9 on: March 26, 2014, 12:13:07 AM »
Get all the cables in your possession that go thru the firewall, measure the "grip" on their grommets, then make the holes. That way the holes won't be too big.
