Thanks for the replies. I got my car last May. It's met all the tests of a factory GT and I believe it is. The vin is 5F07A779369. The codes are; body 65C (2dr/ht standard), color R (Ivy Green Metallic), trim 36 ( Black crinkle vinyl, Bench seat), Date 02U (Jul 2, 1965), DSO 36 (Louisville), Axle A (3:00-1 limited slip), Trans 5 (4speed)
The good is the car is complete but the bad is the trive train was replaced. The origional engine was replaced with a 72 302 with 78 351 heads, the transmission was a 67 toploader from a 390 engine behind a lakewood bellhousing, and the rear end is a 9 inch with 3:50 gears.
I have sense replaced the 302 with a 65 A code engine that was cast in Feb 65 which is too early to count as numbers matching. I got the correct bellhousing and paired it with a T-10 that has a build date of Dec 64.
