Author Topic: Water Pump Question  (Read 2390 times)
Offline 66RagTop
Water Pump Question
« on: March 10, 2014, 11:46:03 PM »
I have a 1966 289 4v V8 A code mustang, built on December 30, 1965 in San Jose. I believe I need to replace the water pump. There is a small leak I've seen on the floor, haven't located the cause yet but will look closer this weekend. If I do choose to replace the water pump can someone provide guidance on the proper water pump to install. During previous repairs to the car over the years I have come to learn that not everything was restored properly from previous owners so I would like to make sure I select the proper water pump to be installed. I have seen posts about cast iron or aluminum water pumps and details about which direction the impeller rotates. I just don't want to presume the type of water pump currently installed is the correct one. Any guidance would be appreciated.
Re: Water Pump Question
« Reply #1 on: March 11, 2014, 12:23:57 AM »
You are looking for a cast iron water pump marked C6OE-A on the front upper housing and FOMOCO in a rectangle on the lower left part of the housing.
Offline outlawincorporated
  • Kangaroo Herder
« Reply #2 on: March 11, 2014, 12:35:10 AM »
+1 to Jims comments.
there are a few on ebay for sale at present, both restored and unrestored examples.
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Offline 66RagTop
« Reply #3 on: March 11, 2014, 11:22:29 PM »
Thanks for the input. When I searched ebay I noticed some water pumps for the C60E-A advertised as either 6fin or 8fin on the impeller. Which is correct for my engine? Also some of the part numbers listed on ebay are listed as C6OE-8505, is this what I should be looking for?
« Reply #4 on: March 12, 2014, 12:49:26 AM »
C6OE-8505-A is the engineering design part number, C6OE-A is the casting number in raised letters on the pump which is the best (and only) means of identification. The housing is cast iron vs aluminum. It gets real crazy when you get to the service part numbers. You want the 8 vane, the 6 vane is the High Performance version used in high RPM applications.
Offline ptosborn1111
« Reply #5 on: March 16, 2014, 08:24:55 PM »
What shall a May built 65' (Dearborn) 289 A code aluminum water pump be marked as? Engine cast of April 21 65', build date April 27th.
Pat
65' Fastback (42k mile car) VIN 5F09A718971
A code 289/4 speed
Body 63A
Color K
Trim 26
Date 07S
DSO 41
71' Boss 351 (Grabber yellow, 2nd owner, 32k miles)
71' Boss 351 (Bright red, 2nd owner, 56k miles)
67' RS/SS 350 Camaro (Butternut yellow project)
« Reply #6 on: March 16, 2014, 09:23:13 PM »
You need a C5AE-8505-C casting water pump. The number is visible on the LH side of the impeller housing. Keep this change level number in mind for your engine - before change L-8.
