Author Topic: Battery Heat Shield For 1971 429CJ  (Read 4048 times)
Offline Mike429cj
« on: March 10, 2014, 07:10:42 PM »
Thought I would give this a shot.  I am looking for a battery heat shield for a 71 429 or 71 Boss 351 car.  I have a restored 71 429 Mach 1 but the shield is missing. Would like to find one. I believe they were only used on these cars and I do not think they are reproduced.
Photo from the 429 Mega site attached.
Re: Battery Heat Shield For 1971 429CJ
« Reply #1 on: March 11, 2014, 01:40:25 AM »
Group 27 battery heat shield. I am pretty sure that they were used on 1970-73 Mustang and Cougar, and at least 1970-1 Torino/Cyclone. Hard to find in undamaged condition. Last one that I found was on a 1972 Q code with A/C.
Offline CW4macret
« Reply #2 on: March 11, 2014, 05:51:13 AM »
NPD sells them
Mac
64.5, 5F07D
66 Convertible 6T08T
71 Mach1 429CJ 1F05J
01 Coupe
05 GT
08 GT500
14 GT500
Offline Mike429cj
« Reply #3 on: March 11, 2014, 09:31:56 AM »
Thank you!  Did not know they reproduced. I did note the application showed thru 1970 but I assume this part would be correct for the often neglected 71 Mustangs too!
Offline CW4macret
« Reply #4 on: March 11, 2014, 06:09:15 PM »
Just be sure to order the group 27
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
« Reply #5 on: March 11, 2014, 10:33:51 PM »
NPD sells them
Sure that is not a reproduction of the C7 version (believe it is). If its says in the ad 67-70 then its not the one. Sold a D00B one to Scott over on the 428 CJ registry when he was looking for a sample needed to investigate getting that version made.
C7 version is shaped differently than the DO. Might be in a thread here - know I've posted on at least two sites pictures and differences. Last nice D00B I bought came out of WCC yard ;) Here is a long and short version of the D00B - not cut off but formed differently.
You do have some references to the later shield Marus provided in a post
http://www.concoursmustang.com/forum/index.php?topic=7235.msg41146#msg41146
Believe I put a D4 version on my 71 CJ ... since that is what I had :(
« Last Edit: March 11, 2014, 10:39:48 PM by J_Speegle »
Offline Mike429cj
« Reply #6 on: March 11, 2014, 11:33:49 PM »
Jeff,
Can you paste the eBay item number in eBay and tell me if this one will work on a 71 mustang 429cj?  The listing says it will fit the 71 with a 429cj but he could be just trying to broaden his sales. I would like to make sure I am getting the correct version of the heat shield.
eBay item#
http://www.ebay.com/itm/181348403215?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D181348403215%26_rdc%3D1
Mike
« Last Edit: March 11, 2014, 11:38:24 PM by J_Speegle »
« Reply #7 on: March 11, 2014, 11:37:54 PM »
Jeff,
Its not the correct version for your car - this is the C7 long/group 27 version. The description even mentions that it only correct for part (should be very early) 1970 not after that point ;)
Belevee it will "fit"  but since the battery sits in the car differently I think they are too long and would have to be shortened - removing the curved edge/end that would have originally been there. The other visible different once installed is the top edge that faces towards the center of the car should run the full length - 67 versions don't On the picture posted in the add it stops (on this version) before it reaches the second set of depressions
Semo and I were both looking into reproducing these back years ago. I backed off so that we would not divide the pie in too many pieces - after all the investment that it would take to make these
« Last Edit: March 11, 2014, 11:43:24 PM by J_Speegle »
Offline Mike429cj
« Reply #8 on: March 12, 2014, 12:22:21 AM »
Ok,
Thanks a lot.  If you were to cut the curved part to make it fit that would totally defeat the purpose of grabbing the air to cool the battery. I will just keep looking for a real one. If you know of a lead on one please let me know.
Email at:  memcclane@comcast.net
mem
Offline sah62
« Reply #9 on: March 12, 2014, 08:37:01 AM »
I still haven't found a way to reproduce that shield economically, but it's still something I have in the back of my mind.
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline Mike429cj
« Reply #10 on: June 05, 2014, 09:59:47 AM »
Ok,
mem
I am still looking for that heat shield for my 429 Mach 1 if anyone has one for sale or knows where to look.
Mike
« Reply #11 on: June 05, 2014, 09:49:37 PM »
I ended up settling for the time being for a D4 on my 71
Good luck with the search
Offline Mike429cj
« Reply #12 on: June 05, 2014, 11:50:38 PM »
Guess I will keep looking. Just looks like such a simple part to reproduce but I guess there is not enough
demand for it.
« Last Edit: June 05, 2014, 11:56:14 PM by Mike429cj »
Offline Anghelrestorations
    • Anghel Restorations
« Reply #13 on: June 05, 2014, 11:51:45 PM »
I may be getting a nearly NOS DOOB battery shield in the next week or two....will see.
Marcus Anghel
www.anghelrestorations.com
