Author Topic: Radio knobs issue  (Read 3717 times)
Offline mwizz
Radio knobs issue
« on: March 10, 2014, 06:33:40 AM »
I have found a genuine radio for my 66 without knobs. I have new Scott Drake knobs which have a small shaft coming out of both of them. However only the tuning side of the radio has a slot for a shaft. The on/off side switch has a shaft coming out of it as well so the Scott Drake knob won't fit on. They are correct knobs for a 64-66 Mustang Radio and the radio is correct. Does anyone know if the shaft on the Scott Drake knobs is removable?
Re: Radio knobs issue
« Reply #1 on: March 10, 2014, 11:00:35 AM »
Are you saying your radio has shafts sticking out of it where the outer knobs should push in?  If so, just pull the ones out of the radio with some pliers.  Best to post a pic before you do anything to make sure it's understood what you're asking.
Offline suskeenwiske
  • 214-347-3628
« Reply #2 on: March 10, 2014, 11:48:09 AM »
Maybe no bearing on the knob issue but does the tuner begin with a 5 or 6?
Ray
« Last Edit: March 13, 2014, 12:46:25 AM by suskeenwiske »
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline mwizz
« Reply #3 on: March 11, 2014, 05:00:06 AM »
Maybe no bearing on the knob issue but does the tuning begin with a 5 or 6?
Ray
Tuning begins with a 6. It is a 5TMZ radio. I will post a pic soon.
Offline mwizz
« Reply #4 on: March 11, 2014, 07:57:13 AM »
Some pics of the radio below. It only has the one shaft sticking out of the left side. Can this be removed to fit the outer knob that also has a shaft?
« Reply #5 on: March 11, 2014, 08:47:42 AM »
I see two different colored metals at the tip of the left shaft.  Could it be that a knob half shaft broke off in the radio?
« Reply #6 on: March 11, 2014, 09:39:23 AM »
My guess is a different type of radio knob was used.  Just get a pair of pliers and pull the brass looking stud out.  Then you can use the correct style knob.
Offline C5ZZ
« Reply #7 on: March 11, 2014, 11:10:54 PM »
Your radio dial starts with a "6" which is generally what was used on 64 1/2 and 65's
66 radio dials start with a "5".  This has been my understanding on how they were.
MCA # 00945
Rangoon Red/Red Interior
Offline fast66
« Reply #8 on: March 12, 2014, 04:14:56 AM »
This is a Motorola radio used in 1965 only.
64½ radios were Bendix. IMHO :-)
The tricky ones are the Philcos that can be either 5TPZ (later 65) or 6TPZ and IIRC all have a 5 (five) as first digit. (sorry wrote 6 at first ...)
« Last Edit: March 13, 2014, 03:44:20 AM by fast66 »
6T09K212784
63A 4 25 21B 951384 5 6
Offline mwizz
« Reply #9 on: March 12, 2014, 09:53:32 AM »
Thanks for the reply. The stud is not coming out as easy as I thought. Do I need to loosen anything before pulling it out or should it come out with brute force.
« Reply #10 on: March 12, 2014, 01:50:13 PM »
It shouldn't be there, so not sure what is going on.  It should look like the other side.  Maybe the unit was worked on or modifed in the past?
Offline Hipo giddyup
« Reply #11 on: March 12, 2014, 07:49:16 PM »
Here's a pic of my radio from my 64 1/2. Maybe this helps...
  • 214-347-3628
« Reply #12 on: March 13, 2014, 12:56:58 AM »
The switch appears to have been replaced with a switch from a different radio; the shaft has a flat side referred to as a 'D' Shaft. Don't try to forcibly remove it, more damage could result. If you have no luck figuring it out and don't have a local repair shop to take it to, I'd be glad to look at it for you, no charge. If so, just send me a PM and I will give you my information.
All the best.
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
Offline mwizz
« Reply #13 on: March 13, 2014, 09:52:48 AM »
All the best.
Ray
Thanks for the offer Ray but I am in Australia, I do appreciate it though. I stopped trying to remove it after the first attempt. I am thinking that it may be easier to remove the shaft from the Scott Drake knob instead.
Mark
