Could someone help me with the mounting location of the washer bag for a june 65 SJ built fastback
There wasn't one fitted originally and would like some advice on positioning of the bracket
Measurement of known correct examples would be a great help
Also some advice on the correct wire from the pump to the switch please
Thanks in advance
G'day mate,
i'll get you started, but i bet london to a brick some other folk know better details than me.
the position asfaik is not difficult at all, there are a couple of dimples (on the inner mudgaurd/fender) where i understand the the two screws are fastened, you should be able to notice them right away . if you do a search using pics you should find some decent examples (?) . the wire i can only go by memory atm , anyone that looks it up will be able to assist far better. but to put you on the right track you should be able to find the correct cable (suited for the month and year you mention) should be, at a guess a simple , single ended cable (not the 66 cable which is different, dual ended if i remember correct), not to be confused with the 66 model which attaches to a different loom and washer pump, and on one end i think i remember has two connections (uses a different washer pump)
all the best
(should have edited I know, since i repeated myself a couple of times, but hey, it just didnt seem that important)
